Thread: Just replace window regulator with motor and...
Results 1 to 6 of 6
ajc549FF Just replace window regulator... 03-15-2011, 07:14 PM
redlinepontiac Re: Just replace window... 03-15-2011, 07:17 PM
ajc549FF Re: Just replace window... 03-15-2011, 11:31 PM
Scottydoggs Re: Just replace window... 03-16-2011, 01:40 AM
JoshsGTP Re: Just replace window... 03-16-2011, 02:36 AM
SnowDrift Re: Just replace window... 03-16-2011, 06:30 AM
  1. #1 Re: Just replace window regulator with motor and...
    Waukesha, WI
    are your window tracks bent?, actually sounds like the front or rear of the windown isnt between the channels properly.
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  2. #2 Re: Just replace window regulator with motor and...
    SE Level Member ajc549FF's Avatar
    Lake Zurich, IL
    Quote Originally Posted by redlinepontiac View Post
    Thank you, Im going to check it out on my next day off and I have been seeing a lot threads saying to clean the switch connections and lube the tracks and such.
    98GTP 3.5in tips, headers, fenderwell intake, 180tstat...3.5pulley?
    1984 Four Winns (Boat) 190 Horizon 19ft open bow...new 350 soon! and Thru Hull exhaust!
    03-07 Duramax Diesel next summer after paramedic is finally over!
  3. #3 Re: Just replace window regulator with motor and...
    try not to use grease to lube the track or regulator, it attracts dust and dirt, try to use graphite. i bought some in a spray can, works great, make your locks feel better than new.
  1. Window Motor Regulator
    By cutiger80 in forum General Tech Discussion
    Last Post: 12-15-2009, 09:09 AM
  2. Window regulator/motor
    By m1sterb0b in forum General Tech Discussion
    Last Post: 11-20-2009, 01:38 PM
  3. Replies: 4
    Last Post: 05-23-2009, 12:21 AM
  4. Window motor and regulator - how difficult?
    By Coogles in forum General Tech Discussion
    Last Post: 05-07-2008, 09:14 PM
