Thread: Key Problem?
Results 1 to 11 of 11
  1. #1 Key Problem?
    SE Level Member Shaun28382's Avatar
    Roseboro, North Carolina, United States
    Hello,
    Today I got my key remade, because honestly key I got it bent slightly and chewed up because of usuage... Problem is that when i use new key the car cranks, then shuts off i got wondering.. so i used my old key.. and then it cranks and stay cranks? Why is this.. Do i need it remade or what?
    First Car - 2001 Pontiac Grand Prix GT
  2. #2 Re: Key Problem?
    you need to do a security learn.
  3. #3 Re: Key Problem?
    May you explain sir?
  4. #4 Re: Key Problem?
    Charles City, IA
    Ignore the install new computer and disconnect battery parts.
    1. Disconnect battery
    2. Install new computer
    3. Reconnect battery
    4. Put emergency brake on to disable daytime running lights (this step is required!)
    5. Make sure all doors trunk and hood are closed leave driver window down and reach in threw window
    6. Try to start. If it doesn't start, leave the key in the on position for 10 min on 97-03 cars and 15 min for 04 and newer cars. The security light should turn off after this amount of time.
    7. Turn off ignition for 3 seconds
    8. Try and start the car. It probably won't start. Repeat step 5 two more times.
    9. If this doesn't work disconnect battery for 5 seconds and then try and start the car.
    If that doesnt work, try this one:
    1. Disconnect battery for 10 sec.
    2. Reconnect battery
    3. Turn key to ON position
    4. Do not try to start vehicle, just quickly click to RUN position to engage security light
    5. Let vehicle sit with key ON for 35 min.
    6. Attempt to crank vehicle. Once vehicle is running, the security light may still be on
    7. If security light is still on, turn key to OFF position for 5 sec.
    8. Turn key to ON position and security light should turn off
    9. Start vehicle and enjoy new PCM
    SMGPFC Two Nipple General
  5. #5 Re: Key Problem?
    SWPA
    I'm glad I happened upon this post. I need to get a second key cut for my GP since I only have one. I'll have to come back to this when I get one.
  6. #6 Re: Key Problem?
    Houston
    Quote Originally Posted by TheOtherNick View Post
    lol..is this like the "Go get the potatoes out of the basement", or "Take the flag off the flagpole" trick?
  7. #7 Re: Key Problem?
    Ohhh!! Thank you very much !!
  8. #8 Re: Key Problem?
    New Brunswick
    On 04 and up to relearn an additional key you just have to start the engine with the origional key then shut right off then start it immediatly with the newly cut key and it's programmed
    Did it on my 04 and current 06
  9. #9 Re: Key Problem?
    Quote Originally Posted by michaelbm View Post
    Haha well, you are lucky then :P
  10. #10 Re: Key Problem?
    Houston
    Thats all I did to my 03. Start it with the original and then start it with the new key.
  11. #11 Re: Key Problem?
    Hmmm... to be honest I didn't think of it like that, but now you say it... Sounds like it haha
  1. BCM Problem?
    By campbech in forum General Tech Discussion
    Last Post: 01-09-2013, 01:51 AM
  2. Problem with gtp
    By Dunes2006 in forum General Tech Discussion
    Last Post: 03-13-2011, 06:25 PM
  3. Ac problem
    By Kenny75k in forum General Tech Discussion
    Last Post: 07-22-2010, 06:38 PM
  4. New problem
    By ryangtp89 in forum General Tech Discussion
    Last Post: 02-09-2009, 07:58 PM
  5. Gas Problem
    By flynn in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-07-2009, 10:27 PM
