Thread: Aeroforce
Results 1 to 20 of 22
tayl5645 Aeroforce 02-23-2011, 08:34 AM
matt5112 Re: Aeroforce 02-23-2011, 09:20 AM
tayl5645 Re: Aeroforce 02-23-2011, 09:21 AM
Bio248 Re: Aeroforce 02-23-2011, 09:27 AM
tayl5645 Re: Aeroforce 02-23-2011, 09:29 AM
Bio248 Re: Aeroforce 02-23-2011, 09:34 AM
matt5112 Re: Aeroforce 02-23-2011, 09:30 AM
matt5112 Re: Aeroforce 02-23-2011, 09:35 AM
tayl5645 Re: Aeroforce 02-23-2011, 09:35 AM
SilvaMan61 Re: Aeroforce 02-23-2011, 02:47 PM
matt5112 Re: Aeroforce 02-23-2011, 07:21 PM
SilvaMan61 Re: Aeroforce 02-23-2011, 07:26 PM
tayl5645 Re: Aeroforce 02-24-2011, 07:26 AM
BillBoost37 Re: Aeroforce 02-24-2011, 09:42 AM
tayl5645 Re: Aeroforce 02-24-2011, 09:47 AM
BillBoost37 Re: Aeroforce 02-24-2011, 09:48 AM
SilvaMan61 Re: Aeroforce 02-24-2011, 03:48 PM
tayl5645 Re: Aeroforce 02-24-2011, 09:52 AM
Bio248 Re: Aeroforce 02-24-2011, 05:12 PM
tayl5645 Re: Aeroforce 02-25-2011, 07:47 AM
BillBoost37 Re: Aeroforce 02-25-2011, 08:26 AM
tayl5645 Re: Aeroforce 02-25-2011, 08:39 AM
  1. #1 Aeroforce
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Just payed for one... OUCH!!!!
    Anyways what all should I know about it before I get it? Also my thoughts are to monitor KR and probably oil pressure.
    Then I have room for two more gauges I was thinking Fuel pressure and boost? Any thoughts
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  2. #2 Re: Aeroforce
    they are cheaply made.
    so don't be alarmed when you get it.
  3. #3 Re: Aeroforce
    Jul 2010
    Michigan
    You are the first person I have ever heard a negative comment about them? Please explain
    2005 GTP Grey
  4. #4 Re: Aeroforce
    i dont like them, but that's me. i am not a fan of digital gauges, nor their price.
    other than that i think they are fairly useful if you watch the right parameters and that it gives you the ability to read/clear codes. i always preferred having seperate gauges for everything and then scanning with a logger when i wanted to check things out.
  5. #5 Re: Aeroforce
    Jul 2010
    Michigan
    The main thing I really want the aero for is the KR. Othen then that I will have other gauges to watch other things.
    2005 GTP Grey
  6. #6 Re: Aeroforce
    Quote Originally Posted by tayl5645 View Post
    if you want to monitor KR all the time youre doing it wrong. just sayin.
    i always like running my car really conservative so i could beat on it mercilessly all day, everyday without worrying about it. most people with cars that they drive often should follow this rule, but most dont and go for a max effort tune which in turn needs to be tuned quite often for variances in weather.
  7. #7 Re: Aeroforce
    It shows me KR.
    Thats nice.
    I can check other things when trying to diagnose issues.
    Thats nice.
    LCD screws up when its below freezing out and stays that way until the cabin warms up.
    Its hardly legible when its like that.
    The buttons are cheap. Don't work all the time.
    There is no auto dim.... which is a major downside if you drive out in the country because the gauge will go from barely bright enough during the day to blinding you at night.
    Even a 12+ switched input for dimming would be nice.
    But alas, its not there.
  8. #8 Re: Aeroforce
    This is also the best way to monitor trans temp.
  9. #9 Re: Aeroforce
    Jul 2010
    Michigan
    I will not go anything extreme. Unfortunatly I have to hold on to the car for some time. Everything will be conservative and very slow at actually doings mods over time.
    2005 GTP Grey
  10. #10 Re: Aeroforce
    MA
    correct me if im wrong but i dont think it monitors oil pressure.
    my setup, once i get an aeroforce and pod, will be electrical oil pressure, mechanical boost, and the aeroforce to monitor kr...... and something else.
    then i may add a hud pod with two more gauges... havent thought about those yet though
    SMGPFC Member #9
  11. #11 Re: Aeroforce
    thats correct.
    our cars lack an oil pressure sender.
    they have a switch instead.
    Which is wired backwards to boot.
  12. #12 Re: Aeroforce
    MA
    ^ thanks matt.....that means, op, you should consider an oil pressure gauge to finish the trio
    SMGPFC Member #9
  13. #13 Re: Aeroforce
    Jul 2010
    Michigan
    Thanks for the info that was what I was stuggling with guess my mind is made up gracias
    2005 GTP Grey
  14. #14 Re: Aeroforce
    Sounds like you got a 3 pod and want other things to put in them.
    Personally I used an aeroforce to have on hand in the car. That way if anything pops up you aren't in the dark.
    Monitoring oil pressure is IMO a waste of time. No matter what you see..there's nothing you can easily do about it before you kill a motor.
    Fuel pressure shouldn't be an issue once you get things up to speed and dialed in
    Example of what an aeroforce is perfect for.. watching KR with climate changes etc and at the next stoplight the car is surging. Hmm a quick TPS reading says 15% and you aren't touching the throttle. Stop for a TPS on the way home and it's fixed quick.
  15. #15 Re: Aeroforce
    Jul 2010
    Michigan
    Thats correct Bill I have the aero and I know boost is going in to the triple gauge and I need one more. Fuel and oil were both suggested to me. Do you have any other ideas?
    2005 GTP Grey
  16. #16 Re: Aeroforce
    second aeroforce
  17. #17 Re: Aeroforce
    MA
    second aeroforce
    Mr. money bags.... which reminds me can i come down when my gauges are ready to go in?
    tayl.. wideband A/F?
    SMGPFC Member #9
  18. #18 Re: Aeroforce
    Jul 2010
    Michigan
    Oh if i had another 250 bucks to drop :P
    2005 GTP Grey
  19. #19 Re: Aeroforce
    wideband would be a great investment for anyone modding their car. the narrowband readings are WAY off from being anywhere near accurate.
  20. #20 Re: Aeroforce
    Jul 2010
    Michigan
    Ive looked at a wideband. That was looking at a year our or so after just dumping almost 500 id like to not instantly put another 160 in the car :P. However, that will be what will go in in the long run. Just not sure If I want to leave the one spot open for that long.
    2005 GTP Grey
  1. Aeroforce??
    By Ricky21 in forum General Tech Discussion
    Last Post: 06-03-2013, 03:41 PM
  2. aeroforce
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 02-04-2009, 08:30 PM
  3. Aeroforce?
    By speedemongtp in forum General Tech Discussion
    Last Post: 11-07-2008, 07:30 PM
