Thread: Aeroforce??
Results 1 to 20 of 32
  1. #1 Aeroforce??
    Minnesota
    Anyone using this how did you hook it up. Because you have to use 3 wire connector right? Did you run it to a fuse and if you did what one? i tried it and it wouldnt power on. Yes I took the red jumper off, then put it back on and pluggeg in only the obdII port and it would power up then turn off and the 2 lights would flash.
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  2. #2 Re: Aeroforce??
    dont they have some form of troubleshooting in their manual?
  3. #3 Re: Aeroforce??
    Pennsylvania
    Jumper is for 04+ only.
    Pretty sure there's like... only a couple spots that won't work. Heard of the radio fuse being used, I think.
  4. #4 Re: Aeroforce??
    Minnesota
    yea I hooked it up like it said i looked at the one online because the one it came with was really brief and didnt have much in it, I think it might be the wire running it to the fuse because i used the radio one
  5. #5 Re: Aeroforce??
    Minnesota
    I dont get why this isnt working. I ran it to the radio fuse and it will turn on for a few seconds then shut off and the 2 red lights start blinking does anyone know whats going on, or how exactly you installed yours? any help would be awesome
  6. #6 Re: Aeroforce??
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    I'm having the same problem. Please let me know if you figured it out
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  7. #7 Re: Aeroforce??
    SE Level Member quadracer960's Avatar
    indiana
    If you have an android phone, or iphone, sell the aeroforce, n buy the torque app for $2 or whatever the amount is, and buy a $35 obd2 port bluetooth adapter and there is your $37 scan gauge.
  8. #8 Re: Aeroforce??
    Slower, Lower Delaware
    Quote Originally Posted by quadracer960 View Post
    I can't get Torque to show data for KR. Any hints?
  9. #9 Re: Aeroforce??
    GTP Level Member
    Pittsburgh
    I have 4 Aeroforces and dont have a problem running them.
    I would guess if you bought it used you may have the wrong Version for your car
    2003 SSEi,
  10. #10 Re: Aeroforce??
    SE Level Member bstuby's Avatar
    charleston, IL
    i just looked at the torque app for the droid and it had 0 bad complaints on it. i think i might get it instead and save myself hundreds of dollars
  11. #11 Re: Aeroforce??
    Quote Originally Posted by bstuby View Post
    read up first. IIRC KR isn't a supported parameter. On our cars if you can't scan for KR, you may as well burn the $39 you'd be spending on the scanner and app.
  12. #12 Re: Aeroforce?? Help!!!!!
    SE Level Member 00GTPDAYTONA500's Avatar
    Mar 2012
    Massachusetts
    My aeroforce is doing the same thing. It worked fine a couple weeks ago when I tested it in the cigarette lighter. I get my pod I wire it up and it turns on, shows to parameters with no readings then powers off. I can go in the menu and it will stay on, as Soon as I hit scan, it shuts off. I hit either of the two buttons, it's just red.. Help!!
  13. #13 Re: Aeroforce??
    Minnesota
    I figured it out lol, the wire running to the fuse was bad
  14. #14 Re: Aeroforce??
    charleston, IL
    the version i was lookin at had it. It was one of the top 5 things
  15. #15 Re: Aeroforce??
    Donating Users
    Indiana
    I'm having the same problem, the backlight and red lights flash and then the backlight goes out and the 2 lights just flash. What should I hook it into?
  16. #16 Re: Aeroforce??
    Donating Users
    Sherman Oaks Ca
    Mine worked great for, like a year, now it just comes on when it feels like it.
  17. #17 Re: Aeroforce??
    Jan 1970
    Maquoketa, Iowa
    99% of the time it's wiring.
    I think it is on 2001+ plus that the obd2 doesn't have the power wire on it. Therefore you have to wire it separately and read the instructions to get the jumpers right if needed. If it powers up then goes off after a few seconds/moments it is most likely getting signal from the obd2 but not any power.
    I would use some 16-18 guage wiring and run the power to the power drop harness under the glovebox, possibly tucked in up to the right. It will have a label on it and should label what each wire is. I would also run the ground to harness as well.
  18. #18 Re: Aeroforce??
    Willoughby, Ohio
    see, i bought mine from another member and when i turn on the car all i get is 2 blinking lights, if i unplug it and plug it back in it works fine
    i didnt get a manual so ive been trying to figure out whats up with the online version
    i have a 99 GT so the guage should get power from the OBDII, which is the only thing its plugged into
    any ideas? im still new to aeroforce
  19. #19 Re: Aeroforce??
    Akron Ohio
    Quote Originally Posted by CTKGP09 View Post
    Just put mine in today. you need the 3 wire conector and the red wire goes to power. then you need to take the Jumper off the back of the Gauge then put it in the obd port
    Or you can come over to my house and Ill hook it up for you.
  20. #20 Re: Aeroforce??
    Kansas
    mine was a 99 gt to lol well still is but i just have a constant power wire connected to one of the 3 wires and it works good.
    SOLD 1999 GT Silvermist TS
  1. aeroforce
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 02-04-2009, 08:30 PM
  2. Aeroforce?
    By speedemongtp in forum General Tech Discussion
    Last Post: 11-07-2008, 07:30 PM
