Thread: coolant change and now 4 dtc's
Results 1 to 8 of 8
  1. #1 coolant change and now 4 dtc's
    Jul 2008
    Tampa, FL
    did my coolant change today, and when i started her up with the new green prestone coolant, i threw these codes. any ideas why?
    [PCM] P0116 - Engine Coolant Temperature (ECT) Sensor Performance (Old) (Immature)
    [PCM] P0134 - HO2S Circuit Insufficient Activity Bank 1 Sensor 1 (SES) (Pending) (History) (Immature)
    [PCM] P0520 - Engine Oil Pressure Sensor/Switch Circuit Malfunction (History) (Immature)
    [PCM] P2432 - Secondary Air Injection System Air Flow/Pressure Sensor Circuit Low (Pending) (Old) (History) (Current) (Immature)
  2. #2 Re: coolant change and now 4 dtc's
    Omaha, NE
    Does your motor leak at all?
  3. #3 Re: coolant change and now 4 dtc's
    Jul 2008
    Tampa, FL
    no...
  4. #4 Re: coolant change and now 4 dtc's
    Omaha, NE
    The reason I ask is because with coolant, oil and airflow issues, its possible that a head gasket could be bad. Hopefully someone has an alternate solution.
    Another question, did you make sure there was no air in the system?
  5. #5 Re: coolant change and now 4 dtc's
    I highly doubt changing your coolant would cause all those sensors to go bad. Did you get water on anything or anywhere, accidentally pull a wire out or forget to hook something back up?
  6. #6 Re: coolant change and now 4 dtc's
    Jul 2008
    Tampa, FL
    well, i probably did get some air in there...idk, the secondary air one could be due to my headers???? maybe???
  7. #7 Re: coolant change and now 4 dtc's
    detroit
    Quote Originally Posted by vailskier3 View Post
    Hi,
    I am the tech manager at Prestone and a mechanic as well. I doubt any of these are related to changing your coolant. If you tell me the year of your car and send your email address to me at Jay.Buckley@Honeywell.com, I will look up and email you troubleshooting instructions for each code.
  8. #8 Re: coolant change and now 4 dtc's
    Being that you changed coolant.. check the grounds on the front of the transmission. Also check your fuses.
    This shouldn't be a head gasket, especially since they are the least common gasket to ever go on these motor.s
  1. LIM change and blocked coolant passage
    By tankerchief in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2011, 03:41 PM
  2. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  3. Coolant Change
    By c002529 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2009, 11:32 AM
  4. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  5. How soon do you change the oil after........
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2009, 03:56 PM
