Thread: Blower motor
Results 1 to 9 of 9
  1. #1 Blower motor
    SE Level Member Wakeboy1337's Avatar
    Dec 2010
    Fort Pierce, Florida, United States
    I've checked all the HVAC related fuses. Good
    I replaced the blower motor resistor with a new one and I still have no fan. I do here a "Click" when I move it all the way up to 5.
    Also I should note that I can spin the fan freely by hand so I know it's not stuck.
    If the motor is bad, is it rebuildable? Another question, how hard is it to pull out?
    Just trying to knock things off the list while I wait for my tax refund and figure out what to do about my tranny.
    Edit:
    Forgot to say, I have the manual unit with Dual Climate.
  2. #2 Re: Blower motor
    Donating Users
    South Deerfield, MA
    I would start by unplugging the blower motor and then putting a meter on the resistor side of that plug and see if you have voltage when the blower is turned on. If you have power there and the blower still does not work, then replace it. Not sure what your car is, but they come out pretty easily on most of the GP's. Take a few screws out and drop it straight down.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: Blower motor
    St. Albert
    I changed out my blower motor.. relatively easy. However does anyone know how to change the dual climate control reading to read in Celsius instead of Fahrenheit? Changing my eng/met on the DIC doesn't seem to do the trick.
  4. #4 Re: Blower motor
    St. Louis
    You will have the pull the HVAC unit from the dash to find this and change it.
    There are 2 main connectors at the back of the HVAC control unit. C and D. At connector D there is pin D7. This is the English/Metric connection point. If this point is grounded it reads Metric-Celsius. If this is open (no ground) it reads English-fahrenheit. The ground originates from ground number G201. BTW - The specific wire you will be looking for is black. If you're handy with a multimeter, set it to ohms - resistance. Check at connector D, pin D7 relative to ground. If it reads a short then its set for Metric. All you'll need to do is open the wire at this point to read fahrenheit.
  5. #5 Re: Blower motor
    SE Level Member twillroth's Avatar
    MN
    Older thread, I know, so I'll apologize up front for the resurrection.
    I gotta change my resistor in my 2002 GT. I'm not worried about the procedure, but am wondering about any tips to getting the carpeted cover off under the glove box. Will it just pull off, or is there a trick to it? I don't want to damage the cover or the plugs that hold it. I've taken door panels and what-not off before and know first hand what a pain it is when they break. I hate loose hardware or components. With 180,000 miles, enough stuff rattles already...
    Thanks for any pointers!
  6. #6 Re: Blower motor
    there should be a couple of retainers holding it up, they just pull out like the door skin retainers. i just used needle nose pliers to pull mine out. watch out for the light bulbs.
  7. #7 Re: Blower motor
    St. Louis
    I use this to remove all my door panels and any other clips similar to that...
    Picked it up at Oreillys for $10. Been an invaluable tool seeing how many window regulators I've done on my GP
  1. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  2. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  3. blower motor
    By bwhicker649 in forum General Tech Discussion
    Last Post: 12-02-2009, 05:13 PM
