Thread: Blower motor doesn't turn on - no signal to blower control module?
Results 1 to 3 of 3
Threaded View
  1. #1 Blower motor doesn't turn on - no signal to blower control module?
    Cliffside Park, NJ
    The Digital Auto/AC control unit (CJ2) on my 98 GTP isn't putting a signal to the blower speed control wire. I performed the diagnostics in the factory service manual three times and have replaced the auto A/C head unit (twice!) per the diagnostics. There is still no current when I back probe the Auto A/C head unit connector (C11) which drives this wire. All three head units work fine with the exception of putting out a voltage to the gray/black stripe blower speed control wire which goes from the digital Auto/AC control unit to the blower control module. I'm really stuck. Any ideas?
    Many many thanks,
    Joe
    Background: The source of all this was likely a surge from the Electronic Evaporator Dryer (EED) unit which was incorrectly installed by the dealer years ago pursuant to a TSB. The mechanic should have spliced the positive output lead from the EED to the positive blower motor wire instead he connected it to the positive lead going to the blower motor controller. The three wire connector going to the blower motor controller has a burn mark by the 12V+ terminal and there is a burn mark where he spliced into the defroster circuit for 12V+ to power the EED. I've since removed this device and repaired the wiring. The blower motor works find but without a signal to the blower control module no current flows to the wiring which goes to the blower motor.
  1. blower motor control module
    By mtz956 in forum General Tech Discussion
    Last Post: 10-03-2010, 10:00 PM
  2. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  3. Turn Signal Module
    By Clar2478 in forum General Tech Discussion
    Last Post: 05-09-2010, 04:02 PM
  4. lights go out and blower doesn't work
    By sparkyth67 in forum General Tech Discussion
    Last Post: 03-06-2010, 10:45 AM
