Thread: Low Oil Light after an Oil Change
Results 1 to 14 of 14
  1. #1 Low Oil Light after an Oil Change
    SE Level Member Dabman's Avatar
    Jul 2010
    New York
    2003 Grand Prix GT
    Hey guys. Simple as that I get a Low Oil Light sometimes when I drive, not every time. Could this be a sensor issue? Also, where is the sensor?
    03 GT, 35% all around, 5000k HID Fogs, Built-in GPS / Rearview Camera / DVD Player
  2. #2 Re: Low Oil Light after an Oil Change
    St. Louis
    Have you checked the oil to make sure it's actually full?
    If it's full and you're still getting the light then the oil level sensor is located on the front of the pan. It's the big nut thing that is screwed into the edge of the pan. Can't miss it. Also check the wiring going to it to be sure it's not screwed up and causing a false light.
  3. #3 Re: Low Oil Light after an Oil Change
    Jul 2010
    New York
    Yes I did check the oil and it is all full. I will jack it up and take a look
  4. #4 Re: Low Oil Light after an Oil Change
    SWPA
    Its probably an oil pressure light. I don't know of any car that has an actual low oil light.
    If it is low oil pressue then its one of two things.
    The sensor is acting funky, or you are on your way to a spun bearing.
  5. #5 Re: Low Oil Light after an Oil Change
    Akron Ohio
    My 97 has a Low light
  6. #6 Re: Low Oil Light after an Oil Change
    Jul 2010
    New York
    Yeah the 97-03's have a low oil level light
  7. #7 Re: Low Oil Light after an Oil Change
    Jul 2010
    New York
    Ok guys Finally popped up the car and took a look. Here is what I see:
    Uploaded with ImageShack.us
    That is the Oil level sensor the wires are suposta be attached to. Where can I buy this harness? I will just strip and attach the loose wires to the new harness.
  8. #8 Re: Low Oil Light after an Oil Change
    id hit up a junk yard for that.
    or you could try e bay for someone who sells pig tails, thats how i got my maf pig tail for my car, cost like 10 bucks shipped.
  9. #9 Re: Low Oil Light after an Oil Change
    Jul 2010
    New York
    Found the part at the Junk Yard. 1st time to a junk yard. Really Fun. Snipped it and sodered and taped it to my car. $2 fix, NICE!!!
  10. #10 Re: Low Oil Light after an Oil Change
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    What happened here!?
    For all your 3800 needs:
  11. #11 Re: Low Oil Light after an Oil Change
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    your engines dirty...
  12. #12 Re: Low Oil Light after an Oil Change
    Donating Users str3etgl0w's Avatar
    Jun 2011
    Saginaw Mi
    did that take care of it?
  13. #13 Re: Low Oil Light after an Oil Change
    Jul 2010
    New York
    Yup I clipped the new pigtail from a car at the junk yard and attached it to the loose wires seen in the picture. Everything works fine, no "Low Oil Level" light. Still not sure why the wires broke at that place.
  14. #14 Re: Low Oil Light after an Oil Change
    St. Louis
    From your pic, it looks like the brown wire is smashed at the harness end. Almost like someone tried jacking it up and missed.
  1. change oil soon light
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2010, 02:38 PM
  2. change oil light.
    By Ironwarrior in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-05-2009, 03:44 AM
  3. Change oil soon light!
    By MARKS99 in forum General Tech Discussion
    Last Post: 07-20-2009, 07:44 PM
  4. Change Oil Soon Light
    By thermanlee in forum General Tech Discussion
    Last Post: 04-29-2009, 08:47 AM
  5. change oil soon light
    By adamlesandrini in forum General Tech Discussion
    Last Post: 03-25-2009, 04:42 PM
