Thread: Synthetic Oils
Page 4 of 4 FirstFirst ... 234
Results 61 to 73 of 73
  1. #1 Re: sythetic oils
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    I use Valvoline oil in my car just because thats what my dad had been using since 1977 and has never experienced any issues. I also change the oil every 3000 miles. I do use Napa oil filters too. Just something my dad has used for a while because his mechanic friends use them.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  2. #2 Re: sythetic oils
    I've always used Valvoline Maxlife. On a side note I want to flush my engine as im about 200 miles from my next oil change, what should I use? My engine has 169,000 miles on it.
  3. #3 Re: sythetic oils
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    [QUOTE=slick2500;518757]I've always used Valvoline Maxlife. On a side note I want to flush my engine as im about 200 miles from my next oil change, what should I use? My engine has 169,000 miles on it.[/QUOTrun amsoil in it for 200 miles, they also make a flush but the oil will remove all the nasty stuff
  4. #4 Re: sythetic oils
    Ok now I have to find someone that sells it.
  5. #5 Re: sythetic oils
    So motorking pulled through and I have a pair of fram XG3387A's sitting here...
    Mobil has less inlet, but more outlet.
    XG is the opposite.
    Will report back with some more oil pressure numbers once I get back into a normal oil change schedule.
  6. #6 Re: sythetic oils
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Ban?
  7. #7 Re: sythetic oils
    What?
    I'm running an XG3387A with Pennzoil 0w-20 synthetic.
    I'm seeing 65 on startup, 57-60 cruising hot.
    65-70 WOT.
    30 hot idle in gear.
  8. #8 Re: sythetic oils
    Apr 2009
    What?
    The spammer that posted something like 15 posts in various threads on the forum.
  9. #9 Re: sythetic oils
    well thats been sorted out thanks to bio i believe.
  10. #10 Re: sythetic oils
    wv
    First off, if you change your oil every 3k miles then just stick to a name brand conventional oil. I usually purchase whatever is on sale. Lately I've been using Mobil's Super 5000 5w-30, though I change it every 3k. It's almost as cheap as Wal-Mart's Super Tech.
    As for those of you who leave your oil in for 6-15k mi., just remember that even though a full synthetic oil can theoretically maintain viscosity for that sort of mileage, your oil filter is still rated for 3k miles. Once your filter becomes plugged a bypass valve will open allowing un-filtered oil to circulate through your engine. If your oil is full synthetic and rated to last that many miles, then please change your filter every 3k and add a quart or so to make up for its displacement.
  11. #11 Re: sythetic oils
    Pennsylvania
    Quote Originally Posted by wvprix View Post
    Unless it isn't. For $9, I can run a 15,000 mile filter that filters better than a 3,000 mile filter and is made of higher quality parts. There's various discussions on such things elsewhere on the forums, though. And that being said, the only way to know when you should change your oil is to keep testing it to find your limit, which is different for ever car and driving style.
  12. #12 Re: Synthetic Oils
    Destroys cars izup69's Avatar
    Iowa
    Ive used royal purple 5-30 forever (don't have anyone that sells amsoil around here or I would run that) I notice better fuel econ. and I drive at least 100mi every day.
    My 06 had 40k miles on it when I switched. I don't change my oil for at least 20k miles. The same way I explain it to my wife. I may spend like 60 bucks to change my own oil using royal purple. But if I have to change my oil every 3k miles b/c I'm using cheap oil then it would cost me triple what I pay.
    I have also read about the wear tests on oil and royal purple and amsoil where the only 2 full syns. to outlast there tests. That's when I switched to royal purple
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  13. #13 Re: sythetic oils
    I can't run syn and change it every 3000 KM?
    Aka 1900 miles?
  1. Sythetic VS Regular 5W30
    By Fubisin in forum General Tech Discussion
    Last Post: 10-21-2009, 10:00 PM
