Thread: Synthetic Oils
Results 41 to 60 of 73
  1. #1 Re: sythetic oils
    delco is the champion labs encore design.
    the mobils are better.
  2. #2 Re: sythetic oils
    Bastard Reptile's Avatar
    Kansas City, MO
    I read a thing on a forum a few months back that even ACDelco was having some product quality control issues. So my faith in them has pretty much deteriorated.
    I've always used them because I get them cheap....but oh well.
  3. #3 Re: sythetic oils
    by the box they are quite the deal.
  4. #4 Re: sythetic oils
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    I run Amsoil and have them test the oil every 10000 miles. I changed my oil last time at 40000 miles and it was still good in all areas, just changed it to make me feel better. My AMSOIL rep changes his every 75000 miles. If that wont make you a believer I dont know what would
  5. #5 Re: sythetic oils
    SE Level Member Crave Energy's Avatar
    Oct 2008
    San Jose
    I use Amsoil 0-30 and Napa Gold or Wix filter.
  6. #6 Re: sythetic oils
    Kansas City, MO
    I've also heard that running thicker oil in street engines isn't good from several other people that study oil and know their stuff. Just because it shows good oil pressure, doesn't mean it's getting to where it's needed, it's kinda like yeah, you have 60 psi at idle, but is it really doing good where it needs to be. Am I right?
    10w30 here, and it's not done me wrong in any motor I've ever had. Again, it goes back to preventative maintenance.
    To touch on the penzoil thing, Read and seen several cases where penzoil sludges...especially up in the top of the engine, around the valve springs and such. Of course, if you have someone that's religious about it, you'll never convince them it's not a good oil. Again though, just from my perspective...never ran the stuff before.
  7. #7 Re: sythetic oils
    Your engine has channels in it for the oil to travel if it is too thick it wont distribute properly and over time it will cause excessive wear to parts that would normally last much longer. It also creates greater oil PRESSURE which puts more pressure on seals gaskets bearings and all other engine parts over long periods of time in daily driving and high mileage situations it isnt good for your engine. 20 w 50 race oil was meant for what it says ,a race. Lots of newer engines have failed due to running the wrong weight of oil and very restrictive oil filters such as a fram on the Ford 5.4. The oil filter bieng too restrictive coupled with too heavy of an oil that wont get up to the top end efficiantly for all of the variable cam timing and other high tech engine components. So moral of the story no matter what oil you choose to run in your ride make sure you run the viscosity that the owners manual says to run.
  8. #8 Re: sythetic oils
    I've noticed slightly less oil pressure with a fram on compared to my normal mobil 1 filter.
  9. #9 Re: sythetic oils
    Thats proof that all the mechanics I have talked to that have made these claims know what they are talking about. The most experienced of them
    told me every engine he hs seen major failure in has had a fram filter on it.
  10. #10 Re: sythetic oils
    Kansas City, MO
    yeah, but the 3800 doesn't have the fancy VVT or anything like that. Not arguing with you, but simple is probably best. I agree that running the heavy oil isn't really necessary since the engines aren't an extreme application that you need anything like that.
  11. #11 Re: sythetic oils
    I'm confused here. I thought we just established excessive oil pressure was bad.
    On the logic side of things here, whats the most popular oil filter?
    If its fram, then you can't argue that the correlation between the number of fram'd engines failing is due to the filter.
  12. #12 Re: sythetic oils
    Pennsylvania
    motorking already said he'd buy a new engine if their filter blew yours up. heck of a warranty to me.
  13. #13 Re: sythetic oils
    It goes both ways Matt. Too restrictive is bad/too much oil pressure not as bad but still bad. IE run what weight oil the manufacturer tells you too and run a good filter.
  14. #14 Re: sythetic oils
    Kansas City, MO
    I think that what he was saying that just because you pour in a heavier oil for the reason of just bringing your oil pressure up gives you a false sense of security. Big whoop if you've got a lot of oil pressure, if the oil is too thick it's not doing any good.
    Roller motors like these don't really need a 50wt oil, a lot of that stuff is designed for flat tapped type motors, and extreme racing conditions where the engine is turning 8000 rpms etc etc etc. The roller bearings that are in the lifters probably need a little lighter oil so that they're well lubricated.
    It's probably not practical to use in most of the newer manufacture engines.
  15. #15 Re: sythetic oils
    GTX Level Member f3racer's Avatar
    dongducheon, south korea
    ok so after using the cobalt on 5w 30 royal purple for the last couple weeks we have noticed a 2 mpg average gain over a the 850 miles we have put on the car. no real noticeable hp gain on the butt dyno. does seem to take a little longer to warm up in very cold weather but also stays cooler through out the drive. looks like the 145k mile ford explorer will be next on the testing block.
    SSG US Army Military Police
    2006 Grand Prix GXP
    http://gmls4.com
  16. #16 Re: sythetic oils
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    Quote Originally Posted by f3racer View Post
    You can't really base MPG on a "better" oil just because you changed it unless you ran exact trips going exactly the same speed with same temperatures, same throttle patterns and many other factors.......
    I've heard many people claim MPG gains on oil and i just can't make sense of the theories. I understand less restriction/friction helping an engine run better but it's nearly impossible to prove a theory unless your car is controlled by a computer running it through identical processes.
    I personally run a synthetic with Lucas Oil Stabilizer. The synthetic usually differs, however I guess my "favorites" are Castrol Syntec Full Syn and Mobil 1.
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  17. #17 Re: sythetic oils
    Quote Originally Posted by postalc38 View Post
    i did that. the oil i removed only had 1k miles on it.
    2006 Grand Prix GXP
    http://gmls4.com
  18. #18 Re: sythetic oils
    SE Level Member gtpdriver's Avatar
    south dakota
    I just switched to synthetic when I got my car at 165000 and now it has 175000. I use mobil one. Also change my oil every 5 k since I switched and its still really clean
    Msp cold air/ram air box and cone, sd ram air hood, 3800 pcm, AL 104's, 180 t-stat, sd headers, 3.4 pulley, aeroforce scanner, sweet wheels that gotta be putting an extra 30 horse to the ground
  19. #19 Re: sythetic oils
    ky
    I use 0-20 sythetic in my 01 gtp 3800 supercharged engine with 105,000 miles on it and change oil when monitor gets down to about 5% and using synthetic it goes for more miles than before i switched, so synthetic does last longer.
  20. #20 Re: sythetic oils
    If you were to have an oil anaylsis done you'd probably find you could run through the OLM twice before you needed to change it.
    Also hows the oil pressure?
    30 seems to be the preferred running weight.
  1. Sythetic VS Regular 5W30
    By Fubisin in forum General Tech Discussion
    Last Post: 10-21-2009, 10:00 PM
