Thread: any Tech Tip for rocker install?
Results 1 to 20 of 32
  1. #1 any Tech Tip for rocker install?
    GT Level Member Mitchstrp's Avatar
    Missouri
    Im keeping my car simple because its still a DD so im doing a 1.9 rocker setup, not rollers just the modified ones. i know im going to get haggled about "cam ftmfw!" but not going too. Sorry nick lol.
    so any tips for what i need and what i need to watch for.
    also a parts list of stuff i may need while im installing the rockers.
    Car is a 97 GTP 86*** miles. 3.5 pulley, SD headers, 180 stat and 3800 Performance tune.
    thanks in advance
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
  2. #2 Re: any Tech Tip for rocker install?
    Never Never Land
    Are you gonna do springs too? If not I think they recommend keeping shifts under 6200 or youll start to have valve float.
    Parts:
    Rockers (Obviously)
    OR Pushrods arent necesary but can't hurt.
    New lifters can't hurt either.
    Rockerbolts Why aren't rocker bolts re-usable? arent they just like any other bolt?
    Valvecover gaskets and the little bushing thing for the bolts if you mess em up.
    Springs if you want....If you do springs you need a springs compressor and one of the things that you hook up to an air compressor and it pressurizes the cylinder that way the valves cant fall out.
    I'm sure im missing some stuff, this is just what I know from reading since i wanna do rockers instead of a cam too.
  3. #3 Re: any Tech Tip for rocker install?
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    You doing springs too? Its all pretty straight forward just make sure you buy the reusable bolts and if you do springs remember to use compressed air to keep the valves up.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  4. #4 Re: any Tech Tip for rocker install?
    Feb 2010
    Oklahoma City, OK
    I lost...
  5. #5 Re: any Tech Tip for rocker install?
    Never Never Land
    I just ninjad ya..its ok...you probably know more about it since youve done it...therefore you win.
  6. #6 Re: any Tech Tip for rocker install?
    Feb 2010
    Oklahoma City, OK
    Lol!
  7. #7 Re: any Tech Tip for rocker install?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Rocker bolts are TTY. They cannot be reused unless you get some from say comp cams thats reusable.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: any Tech Tip for rocker install?
    Never Never Land
    Quote Originally Posted by 01gpgt01 View Post
    TTY? I know comp sells re-usable bolts.
  9. #9 Re: any Tech Tip for rocker install?
    Charles City, IA
    torque to yield, stretch bolt.
    get reusable bolts
    105 springs
    new valve cover gaskets and gromets
    some assembly lube
    SMGPFC Two Nipple General
  10. #10 Re: any Tech Tip for rocker install?
    I had rockers...they were boring.
    I DD'd a cammed car too.
  11. #11 Re: any Tech Tip for rocker install?
    Missouri
    is changing the rockers and springs something someone with little expierence could do? the only hard parts seem like getting to the back and changing the springs.
  12. #12 Re: any Tech Tip for rocker install?
    Never Never Land
    You probably could do it. It'll make sense once you get the valvecover off and you see how everything works
  13. #13 Re: any Tech Tip for rocker install?
    Missouri
    okay, i think im going to go with 1.84 roller rockers so i dont have to change springs. Push rods are pretty straight forward, correct? not to difficult
  14. #14 Re: any Tech Tip for rocker install?
    Never Never Land
    Pushrods just pull out. If you have all the rockers on one bank off you can probably take out every pushrods in like 2.2 seconds Ok not quite but you get what I'm saying
  15. #15 Re: any Tech Tip for rocker install?
    Charles City, IA
    There is a write up floating around some where.
  16. #16 Re: any Tech Tip for rocker install?
    Charles City, IA
  17. #17 Re: any Tech Tip for rocker install?
    Jersey
    keep the rocker bolt holes free from debris and oil before you put the new bolts in and torque down. I rotated the motor manually re-checking torque on the bolts.
    q-tips work well
    I didn't use any cam lube, just lubed the rockers with oil before putting them in.
    16' wrx sti- stock
  18. #18 Re: any Tech Tip for rocker install?
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    get reusable bolts
    this is what ive never understood.. torque to yield bolts need replaced after removal.. because of bolt stretch..correct?
    torque is the amount of bolt stretch applied to a fastener.. so always replace used bolts since they've been stretched?
    or is it on particular bolts (ie TTY), once it's been torqued it wont return to its normal length?
    i torque sh*t all day at work, but i'm in assembly, assembling new parts not reused. never gave it a thought thanks.
  19. #19 Re: any Tech Tip for rocker install?
    Missouri
    well when my parts come in, theyre are on back order as of now, ill take pics and hopefully have some insight on how to do this. maybe a write up, who knows.
    hopefully its as easy as some of you say.
  20. #20 Re: any Tech Tip for rocker install?
    Charles City, IA
    Quote Originally Posted by oneil.GTP View Post
    Yeah they stretch. You torque them to a certain and then some many degrees extra.
  1. ARP lube for rocker install. What for?
    By Rust in forum General Tech Discussion
    Last Post: 12-18-2011, 10:04 AM
  2. 1.9 Modified Rocker Install
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2011, 06:59 PM
  3. write up on rocker install?
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 08:07 PM
  4. Rocker install
    By mikesarebetter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2010, 06:07 PM
  5. 1.9 modded rocker install
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 12:38 PM
