Thread: ARP lube for rocker install. What for?
Results 1 to 7 of 7
Rust ARP lube for rocker install.... 11-12-2010, 06:08 PM
Bio248 Re: ARP lube for rocker... 11-12-2010, 06:11 PM
Rust Re: ARP lube for rocker... 11-12-2010, 06:51 PM
Bio248 Re: ARP lube for rocker... 11-12-2010, 07:10 PM
Rust Re: ARP lube for rocker... 11-12-2010, 07:17 PM
TheOtherNick Re: ARP lube for rocker... 11-13-2010, 12:09 AM
tod1d Re: ARP lube for rocker... 12-18-2011, 10:04 AM
  1. #1 ARP lube for rocker install. What for?
    Donating Users Rust's Avatar
    Jun 2010
    Canada
    If the weather cooperates this weekend I plan on installing my ER rockers, #105 springs, Comp push rods, and replacing the coolant elbows.
    The ZZP rocker install kit comes with ARP assembly lube. What is it for?
    I see no mention of it in the write ups and it is definitely not for the rocker bolts.
    The only thing I can think of is maybe it is used to hold the valve cover gasket in place while you move the valve cover around. Anyone know?
  2. #2 Re: ARP lube for rocker install. What for?
    keeps the torque specs proper when youre torquing the bolts down. make sure you clean the bolt holes very well (q-tips).
  3. #3 Re: ARP lube for rocker install. What for?
    Jun 2010
    Canada
    So clean the junk out of the bolt holes and a light coating on the thread of the rocker bolts?
  4. #4 Re: ARP lube for rocker install. What for?
  5. #5 Re: ARP lube for rocker install. What for?
    Jun 2010
    Canada
    Thank you!
  6. #6 Re: ARP lube for rocker install. What for?
    Charles City, IA
    then lube up your rockers with some valve train assembly lube.
    SMGPFC Two Nipple General
  7. #7 Re: ARP lube for rocker install. What for?
    May 2008
    Winnipeg, MB
    Quote Originally Posted by TheOtherNick View Post
    the ARP lube?
    2007 Pontiac Grand Prix
  1. 1.9 Modified Rocker Install
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2011, 06:59 PM
  2. write up on rocker install?
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 08:07 PM
  3. Rocker install
    By mikesarebetter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2010, 06:07 PM
  4. Total lift after rocker install.Question
    By TDCRacing in forum General Tech Discussion
    Last Post: 12-06-2008, 04:03 PM
  5. 1.9 modded rocker install
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 12:38 PM
