Thread: 1.9 modded rocker install
Results 1 to 8 of 8
  1. #1 1.9 modded rocker install
    Gainesville, FL
    Hello group:
    Installing modded 1.9's today. I have the ZZP instructions. Any last minte advice? I have a tilter and the appropriate tools. Tricks, tips or issues?
    Thanks,
    Dean
    2k1 GTP Sedan, Black. 3.4, FWI, 180, PT, Borla, Headers, AL104's, GMPP handling kit, Vogtland/ AGX, 12 in brakes/SS lines/ Hawk HPS, 1.9's
    2k4 Maxima SE A5 Black, K&N, wifes
    PEMs and two 3" DP for sale.
  2. #2 Re: 1.9 modded rocker install
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    As soon as you get the valve covers off, clean the gaskt grooves, put about 6 tiny dabs of RTV spaced out in the gaskets grooves and install the gasket. This will allow time for the RTV to setup for a bit and hold the gasket in place when installing the covers later.
    Make sure you clean out the rocker bolts holes. I don't have an air compressor so I used Q-tips to get all of the oil and metal shavings out.
    Assembly lube on the rocker pivot points, valve and pushrod contact surfaces.
    Clean the vc to heads mating surface.
    properly torque the rocker bolts and vc bolts. Blue (service removable)loctite threadlock
    rocker bolts
    stock 11 lbs ft + 90*
    ZZP reusable 25 lbs ft
    PRJ 30 lbs ft - PRJ recommends red locktite (service removable)
    VC bolts 89 lbs in... Inch pounds
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: 1.9 modded rocker install
    GTP Level Member David99GTP's Avatar
    Florida
    I could not find a torque wrench that went below 10. I ended up buying a cheapo version that had the indicator needle. I hope its not super critical. They are snug and I dont fell I over tightened them. If my VC leak after I get it all put back together that is gonna P me off lol.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  4. #4 Re: 1.9 modded rocker install
    St Louis MO
    Quote Originally Posted by David99GTP View Post
    Rocker torques specs are way more important - my guess most people don't use a torque wrench on the vc bolts. I'm a bit anal. If it has a spec I'm using a torque wrench. Your vc will likely not leak as long as the gasket is install properly.
    2010 Camaro SS LS3
  5. #5 Re: 1.9 modded rocker install
    Gainesville, FL
    Thanks to all, especially Gandalf. Without him, I couldn't have done it.
    The car cranked on the first attempt. We had taken our time, stopped for lunch and killed a half dozen long necks along the way.
    The car pulls harder when it gets in the upper rpm range. The 40mph kick down hits hard. An initial scan with skewed fuel trims netted only blips of KR from 0-90. Once the trims are settled in, we'll tune in more timing. WOOT!
    Dean
  6. #6 Re: 1.9 modded rocker install
    St Louis MO
    Glad it all turned out well and that was nice of Bill to help out.
    2010 Camaro SS LS3
  7. #7 Re: 1.9 modded rocker install
    I live here. UR LOSN's Avatar
    Rockford, IL
    job well done. any pics?
  8. #8 Re: 1.9 modded rocker install
    Gainesville, FL
    No pics taken. i should have but I was trying to get it done. I had taken up enough of Bill's day without stopping for pics.
  1. 4T65E Differential INSTALL PICS!!!
    By Trannyman95 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-23-2017, 12:15 AM
  2. Stereo INSTALL.....need help
    By TMOTA503 in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2008, 11:01 PM
  3. easiest shift kit to install ?
    By bayareagtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2008, 09:18 AM
  4. ZZP Fuel Logs Install [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2008, 12:28 AM
  5. did I do an install on your gp today?
    By s1795so2 in forum Midwest
    Last Post: 01-06-2008, 06:56 PM
