if the key is hard to push in the lock i'd try some graphite lock spray. if its just the tumbler being dry it should help.
sadly the only way to get the tumbler out is if the key is turned to run, theres a hole you push a pick into on the top of the column and then you pull the tumbler out with the key in it still.
