Thread: low coolant light
Results 1 to 4 of 4
  1. #1 low coolant light
    Mar 2012
    Michigan
    Hello
    I have an 01 3.8L pontiac grand prix gt not supercharged my low coolant light comes on in the morning and stays on for about 10 minutes ive checked the coolant in the radiator and reservoir and both are full, not leaking it either. changed out the thermostat just replaced the upper and lower intake gaskets and it still comes on..Also would like to know how to hook the cruise control back on since the person who fixed my car didn't hook it back up..is there a picture or instructions to hook the end of the cruise control cable back up so I can do it myself
    Thank you
    Sammie
  2. #2 Re: low coolant light
    take the pass side head light out, then on the side of the rad is the low coolant sensor, its either bad, or dirty. theres a clip on it, then you just pull it out. a o ring seals it. clean it or replace it. or unplug it and the light will never come on again.
    its kinda hard to describe how the cc cable linkage gets clipped on. take a good hard look at the throttle cable make it look the same. puling the throttle to full open helps get it clipped on, then route the cable in the groove.
  3. #3 Re: low coolant light
    Mar 2012
    Michigan
    Thank you!...its the plastic piece that the cruise control linkage is hooked to that is not staying on
  4. #4 Re: low coolant light
    this thread has some pics. maybe it will help. http://www.grandprixforums.net/threa...-throttle-body
  1. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  2. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  3. Coolant Light
    By Bakerdd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-07-2011, 05:34 PM
  4. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
