Quote Originally Posted by ExLimey View Post
Now that you have a good key for your car, you can make additional keys easily. The PK3 keys are easy to program yourself at least for 97-03 cars. I've bought several online for both my GPs(about $12/key), had them cut by a locksmith(about $5) then programmed them myself. It worked out to be less than $20 per key. I keep a non PK3 key as a pattern for the cut.
All you do is use a good key, turn it to on then back to off. Put in the new key and turn it on then off and it should be programmed.
dont have a coded key or factory alarm.
