Thread: help me break 13's :/
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 74
  1. #1 help me break 13's :/
    Jersey
    Mods right now are
    -genV/ L36 block
    -1.9 rollers
    -N*
    -pacesetter headers
    -slp catback
    -dyno tuned on a 3.6 mps
    The best time i got-
    With a 2.0 60' and .5xx r/t, best time it ran was a 14.4 @ 95
    I was going to go intercooler but, i was thinking of going a different route, xp cam, 42lb injectors, and meth, with the smallest pulley i can. The only thing that worries me is my trans was built using the dual chain, since my car is still a dd.
    realistically what kind of trap increase should i expect with cam, and meth?
    16' wrx sti- stock
  2. #2 Re: help me break 13's :/
    Banned - Busted For Scamming
    Feb 2009
    Just intercool it and turn up the boost. There is no reason to break into the motor for 13's.
  3. #3 Re: help me break 13's :/
    Donating Users blowfishRus6's Avatar
    g.a.
    what kind of elevation are you at????
    with intake and headers i was traping 97-98 running 14.1 with 2.1 60"
    in 95* heat with a D/A in the 3500" with intake, headers and rockers i was traping 96-97 with 2.0 60" at 14.2
    i know you just got it tuned so i dont think that is the issuies, or maybe it is....... idk.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #4 Re: help me break 13's :/
    put a different pulley on it and you will be in the 13s.
  5. #5 Re: help me break 13's :/
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    have you scanned for KR? maby the tune needs work?
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  6. #6 Re: help me break 13's :/
    Jersey
    its all tuned out, no KR, a/f is good, I brought it to a reputable place. He did say im running out of injector and my stock ones are almost maxed without going static.
    i just think its harder to break into the 13's than people say. I don't know why my car is being such a turd.
    16' wrx sti- stock
  7. #7 Re: help me break 13's :/
    Charles City, IA
    I only ran a 14.1 on a 3.4 setup with rockers.
    SMGPFC Two Nipple General
  8. #8 Re: help me break 13's :/
    Jan 1970
    Maquoketa, Iowa
    There's something wrong with that... I trapped 101mph on a 3.4 setup with downpipe. Usually just add 1.9's to a 3.4 setup and your consistent high 13's.
  9. #9 Re: help me break 13's :/
    Charles City, IA
    Quote Originally Posted by FoSHO99 View Post
    lots of wheel spin.
  10. #10 Re: help me break 13's :/
    Jersey
    why is my car so slow?
    16' wrx sti- stock
  11. #11 Re: help me break 13's :/
    in a house
    You should be in the 13's with that set-up. Something is wrong. I was hitting 13's all day long with a 3.4 rocker set-up
  12. #12 Re: help me break 13's :/
    Right...because I ran a 13.8 on a 3.5" with PEM's/DP and 1.84's.
    I think the tune is off somewhere IMO.
  13. #13 Re: help me break 13's :/
    g.a.
    something is off. stock gtp's can trap 95.....
    was the track at crazy high elevation???
    its slow.
  14. #14 Re: help me break 13's :/
    Jersey
    I don't think so dude, This part of jersey is around sea level
    16' wrx sti- stock
  15. #15 Re: help me break 13's :/
    g.a.
    give all the facts, it dont add up.
    car put what, 260 to the wheels?? a stock gtp puts about 200 to the wheels and can still trap 95.
    only thing i can think of is crazy amounts of torque management in the tune.
    if it was at sea level, and it was not crazy hot, either something is wrong with the car, or the tune is off. i would think your mods should deff trap in the 100's
    its slow.
  16. #16 Re: help me break 13's :/
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    When are you gonna run the honda again?
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  17. #17 Re: help me break 13's :/
    Jersey
    Quote Originally Posted by ls6velless454 View Post
    that kid is loosing his lisence again
    the car snapped an axle, so he had to dish out more to have the engine mounts moved so its lined correctly, he just got the car back on the road then gets 4 tickets
    16' wrx sti- stock
  18. #18 Re: help me break 13's :/
    Oct 2008
    Northern Illinois
    Yeah man something is wrong, there is no reason why you shouldn't be well into 13s consistant. I just can't think of anything except maybe the tune, but you got it dynotuned right? You could probably be fine with a 3.4 on your setup, can give that a try.
  19. #19 Re: help me break 13's :/
    let me tune it, pulley it, and drive it.
    you'll have your 13s.
  20. #20 Re: help me break 13's :/
    Jul 2008
    nj
    If your injectors are almost maxing, your too rich. You should be in the 13s with ease. I had a 2.1 60 foot on my set up with a 3.4, cai and 3" dp and I ran a 14.1. Your tune sux...don't go back there for another tune
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  1. First Break down
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 02-05-2010, 01:24 AM
  2. Break n oil
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-13-2009, 11:27 PM
  3. not new but took a break
    By WhiteDevil in forum Introductions/Noob Questions
    Last Post: 10-06-2009, 07:59 AM
  4. What did I break?
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2009, 02:22 AM
  5. break job help
    By reinke in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 08:42 PM
