Thread: help me break 13's :/
Results 21 to 40 of 74
  1. #21 Re: help me break 13's :/
    Oct 2008
    Northern Illinois
    Post up an acceleration vid
  2. #22 Re: help me break 13's :/
    Jersey
    Quote Originally Posted by Damojo2003 View Post
    If your injectors are almost maxing, your too rich. You should be in the 13s with ease. I had a 2.1 60 foot on my set up with a 3.4, cai and 3" dp and I ran a 14.1. Your tune sux...don't go back there for another tune
    The car put down 252 fwhp on a mustang dyno. The place i brought it to is extremely recommended in the w-body, cobalt, and ls world
    to the 3.4 suggestion, i would but, since my injectors are almost maxed out on a 3.6, i might have some trouble.
    i need 42#'a and meth, then well see what happens
    16' wrx sti- stock
  3. #23 Re: help me break 13's :/
    Jersey
    Quote Originally Posted by BwolfGT View Post
    i will when i get a chance
    16' wrx sti- stock
  4. #24 Re: help me break 13's :/
    Quote Originally Posted by 99prixgt View Post
    dmojo is right, you shouldnt be near maxxed on a 3.6. youre running too rich and its robbing you of power. get a wideband on the car and see what she is reading. if its any fatter than 11.2:1 then youre using too much fuel to quelch out the knock.
  5. #25 Re: help me break 13's :/
    Jul 2008
    nj
    How much timing and at what AFR? I was not suggesting the 3.4...I was just telling you that I ran faster with alot less work. With that compression...you are basically equivalent to the 3.4 on a L36
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  6. #26 Re: help me break 13's :/
    Jul 2008
    nj
    bio...that car might need to run a bit fatter than 11.2 but definitely not in the 10s. When you said it got dyno tuned at a good place....did this good place check your plugs and gap? I want more information on your tune
    FOR SALE
  7. #27 Re: help me break 13's :/
    i always liked to dial in my fueling, then timing, then throw on whatever pulley ran without knock. when these cars run on the fine edge of lean and blown up they are very fast.
  8. #28 Re: help me break 13's :/
    Donating Users blowfishRus6's Avatar
    g.a.
    apperently that place is bad ass with tunes.......... just ask quik-gt.
    what was it, intake, down pipe, 3.4 and he went 13.0 at 103........
    a guy just recently with an ss camaro with a lid and mufflers thru an auto put down 280 on a mustang dyno and went 12.8 at 108 with a 1.9 60' i think. if your car put really put down 260 (like said, you can get a dyno to read anything you want to really, maybe he pulled your leg a little) and you cut a 2.0 60" then all i can think of is you let of early, or there was a 50mph head wind.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  9. #29 Re: help me break 13's :/
    Jersey
    the dyno sheet has some info on it, ill post a pic.
    damojo2003, were you on 206 in hillsborough the other day, (i think sunday) i thought i saw a car that looks like the one your selling
    16' wrx sti- stock
  10. #30 Re: help me break 13's :/
    Jersey
    I'm running autolite 103's with a .55 gap, i just did plugs 1 week before i got it tuned
    16' wrx sti- stock
  11. #31 Re: help me break 13's :/
    Jul 2008
    nj
    Nah...that was not me. Must had ben some one else. A bit of advice, you need to think a bit different with the plugs. What ever the link says below for your mods, go one lower. Your added compression plays a lot with your tune. In order for the L67 to make the same power as your L36, it needs an additional 2# boost....give or take. Then take in account that you run a gen V which is more efficient and I think it makes more boost than the gen 3 m90...some one correct me if I am wrong. I would pull the plugs and gap them at .050 and take it from there. IMO...that .055 is too wide of a gap for the 103s
    What springs are you running?
    what wires are you using? make sure there is good contact and only use dielectric grease on the ceramic portion of the plug.
    What afr?
    how much timing?
    Is it that place in toms river? If it is...I am extremely dissapointed in them. I gave them the original file to use as a base for them to start tuning for a local and you can't even run 13s...that is honestly pathetic. You should be makin more than 250sh whp
    link for ref..
    Ontario Quebec Club Grand Prix :: Which Spark Plugs Should I Run?
    FOR SALE
  12. #32 Re: help me break 13's :/
    Jersey
    the print out
    I'm running l76 springs, using prj wires, im really unsure of timing, he said it was set too high, so he lowered a bit
    16' wrx sti- stock
  13. #33 Re: help me break 13's :/
    Topeka, KS
    Wow maybe you need a driver mod. No offense... I'm not perfect at the tree either. Shed as much weight as possible too.
    I ran a 14.1 @ 97 2 years ago with PEMS, 3.4 GenIII, 3" DP and a good tune.
    When you launch do you spin like a mofo or do you hook pretty well ? What's your 60 foot like.
  14. #34 Re: help me break 13's :/
    in a house
    Why are you maxed @ 5600 rpm?
  15. #35 Re: help me break 13's :/
    Jersey
    Quote Originally Posted by rynoman03 View Post
    not much tire spin at all, i had 25psi in the tires and my seat as far foward as i could
    16' wrx sti- stock
  16. #36 Re: help me break 13's :/
    Oct 2008
    Northern Illinois
    And you're only trapping 95 too? Wtf somethins up.
  17. #37 Re: help me break 13's :/
    Jan 1970
    Maquoketa, Iowa
    You have 3.29's as well. It seems like your shifting at factory shift points? There is something amiss. A 2.160ft is average as well.
  18. #38 Re: help me break 13's :/
    SE Level Member Boosted02GTP's Avatar
    Feb 2009
    Long Grove IL.
    My stock gtp went a tad slower than yours..can't be right man?
    2002 GTP coup 14.6 @ 94mph stock baseline 5-7psi.
    Headers w/o cat, plugs, fwi, 180* t-stat, 3.4, mail-in tune. 13.9 @ 99.75mph 2.2 60'..seeing only 7psi and a fresh set of weatherman snow tires
  19. #39 Re: help me break 13's :/
    Jul 2008
    nj
    It is easy to get rid of knock when you lower the timing. Where in NJ are you? See...i knew that place sucked from the very first gp that was tuned there. The first guy said he did such a good job and I only have 2-3* of KR.....that to me is unacceptable if I am paying for a dyno tune. A tune consists of more than just strapping the car on the dyno and messing with the computer. Regap the plugs and you need a real tune
    FOR SALE
  20. #40 Re: help me break 13's :/
    GTP Level Member
    Nov 2008
    MA
    Quote Originally Posted by FoSHO99 View Post
    x2 on factory shift points
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  1. First Break down
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 02-05-2010, 01:24 AM
  2. Break n oil
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-13-2009, 11:27 PM
  3. not new but took a break
    By WhiteDevil in forum Introductions/Noob Questions
    Last Post: 10-06-2009, 07:59 AM
  4. What did I break?
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2009, 02:22 AM
  5. break job help
    By reinke in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 08:42 PM
