Thread: Need help with intake!
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
  1. #41 Re: Need help with intake!
    GT Level Member VejGTP's Avatar
    USA
    You see the hard piece of plastic with the wires connected to it? That has to I repeat HAS TO be in between the air filter and tb. Take a good picture of your stock intake and I will draw what needs to be done on it.
    And here's one with my cone filter sitting there so you can see the size of it.
    Sorry about the quality, they were taken with my phone
  2. #42 Re: Need help with intake!
    Charles City, IA
    Attach the circled sensor to the tb with a rubber clamp. Then either run some pipe from that sensor close to the fender well or just put your filter on the other end of the sensor.
    SMGPFC Two Nipple General
  3. #43 Re: Need help with intake!
    USA
    Would it be the same to just leave the sensor where it's at then take the stock box out and attach some pipe so the filter gets closer to the fw? Or would that not work right
  4. #44 Re: Need help with intake!
    It would, but part of the problem in the intake is that coregated piping.
  5. #45 Re: Need help with intake!
    USA
    Hmm.. Any suggestions on what I could use instead and where u could get it?
  6. #46 Re: Need help with intake!
    get a rubber coupler from the plumming section of your local home depot.
  7. #47 Re: Need help with intake!
    USA
    That all? Also how big should I get?
    Sorry about all the questions =(
  8. #48 Re: Need help with intake!
    MO
    just so you know, inside of where the coupler meets the 45* bend, i put a smaller plastic tube that forces the bend to stay open since it's rubber. Otherwise it won't grab and will just fall off
    See if those help you out at all
    <brandonl2000> LMAO D!!
  9. #49 Re: Need help with intake!
    USA
    Thanks!
  10. #50 Re: Need help with intake!
    Charles City, IA
    Quote Originally Posted by ZR1Vette09 View Post
    Where were you two pages ago. LOL There ya go.
  1. New air intake
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2009, 02:50 AM
  2. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  3. ram air intake
    By jprovinsal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2009, 08:17 AM
  4. Intake Q
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2008, 02:35 PM
  5. intake
    By SahotaGTP in forum General Tech Discussion
    Last Post: 06-26-2008, 11:02 PM
