http://img69.imageshack.us/img69/6832/pic1p.jpg
And here's one with my cone filter sitting there so you can see the size of it.
http://img29.imageshack.us/img29/1949/pic2vo.jpg
Sorry about the quality, they were taken with my phone
http://i426.photobucket.com/albums/p...g?t=1262022933
Attach the circled sensor to the tb with a rubber clamp. Then either run some pipe from that sensor close to the fender well or just put your filter on the other end of the sensor.
Would it be the same to just leave the sensor where it's at then take the stock box out and attach some pipe so the filter gets closer to the fw? Or would that not work right
It would, but part of the problem in the intake is that coregated piping.
Hmm.. Any suggestions on what I could use instead and where u could get it?
get a rubber coupler from the plumming section of your local home depot.
That all? Also how big should I get?
Sorry about all the questions =(
http://photos-e.ak.fbcdn.net/hphotos..._4433298_n.jpg
http://photos-c.ak.fbcdn.net/hphotos..._7324451_n.jpg
just so you know, inside of where the coupler meets the 45* bend, i put a smaller plastic tube that forces the bend to stay open since it's rubber. Otherwise it won't grab and will just fall off
http://photos-h.ak.fbcdn.net/hphotos...0_572374_n.jpg
See if those help you out at all
Thanks!
