Thread: Need help with intake!
Results 21 to 40 of 50
  1. #21 Re: Need help with intake!
    MO
    I'll get some more pics of my 06 setup posted for you. Most guys may steer you away from it since its a short ram and only sucking in hot air but i will hopefully be working on a homemade heat shield soon
    <brandonl2000> LMAO D!!
  2. #22 Re: Need help with intake!
    GT Level Member VejGTP's Avatar
    USA
    Yeah I watched a video of a guy that had a ram air intake installed on 2 different cars. He made a custom heat shield with some cheap steel and foil tape.
    I wouldn't mind seeing pictures. I'll probably end up doing something easy but I'm always willing to learn more and see more.
  3. #23 Re: Need help with intake!
    Quote Originally Posted by ZR1Vette09 View Post
    What he's talking about is removing all the pipe and the mass air flow and putting the cone filter straight onto the throttle body. Honestly, you probably shouldn't even worry about that yet, this is usually done with intercooled cars
    Sorry, didn't notice it was a 7th gen. But see what 01GTP did, that'll be more than enough.
    As soon as you get more serious about modding, TB intake will probably be the best.
  4. #24 Re: Need help with intake!
    Charles City, IA
    He can not put the filter directly on the TB. His mas air flow sensor is separate from his throttle body. It would go TB then Maf then filter like I have minus the chunk of wizair tubing.
    SMGPFC Two Nipple General
  5. #25 Re: Need help with intake!
    Joliet, IL
    fukk CAI/FWI......flow>temp and if your worried about heat soak tune around it...
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  6. #26 Re: Need help with intake!
    I realize that, TB intake is the term that means intake filter as close to throttle body as physically possible.
  7. #27 Re: Need help with intake!
    USA
    Hmm.. I guess if I wanted I could put it directly on the TB but I would need to zip tie the sensor somewhere so my check engine light wouldn't come on
  8. #28 Re: Need help with intake!
    Charles City, IA
    Not every one understands that tho. Not hard to add one extra letter MAF instead of TB.
  9. #29 Re: Need help with intake!
    Will remember that for the future!
  10. #30 Re: Need help with intake!
    Charles City, IA
    Quote Originally Posted by VejGTP View Post
    Get some rubber connectors. Connect your maf to your tb with one then put the filter on the other end of the maf. You can not just zip tie that up in the engien bay or your car will think it is not getting any air flow.
  11. #31 Re: Need help with intake!
    USA
    So if I tie it and the check engine light doesn't come on then it's in an ok spot?... Also how come not many people have the filter directly on the TB? Pictures I see usually have at least a little piping or tubing..
  12. #32 Re: Need help with intake!
    GTP Level Member tazyboy28's Avatar
    home town
    why is that only for intercooled? and is the maf even used in conjunction?
    specs:2007 GP GT, wizair intake, ZZP headers, 3inch high flow cat downpipe. SLP power flo exhaust
  13. #33 Re: Need help with intake!
    Charles City, IA
    You see the hard piece of plastic with the wires connected to it? That has to I repeat HAS TO be in between the air filter and tb. Take a good picture of your stock intake and I will draw what needs to be done on it.
  14. #34 Re: Need help with intake!
    MO
    Quote Originally Posted by tazyboy28 View Post
    its not only for intercooled, i said most people with intercoolers do that. Also, i guess i was wrong about the MAF because i didn't realize it was built into the throttle body on the older ones
  15. #35 Re: Need help with intake!
    Donating Users blowfishRus6's Avatar
    g.a.
    this man, this...
    i added the rubber coupler at the TB so the MAF would not get as hot from the TB. the MAF has to be inline with the filter and tb. it can not just be zip tied up in the engine bay.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  16. #36 Re: Need help with intake!
    USA
    I'll get the picture up here in a little while, you want me to put it on here or message it to you?
    Quote Originally Posted by blowfishRus6 View Post
    this man, this...
    Yeah, I just figured if it was tied in a certain spot that it would still detect airflow and be alright, but I was just taking a guess at it.
    Also it seems like you guys have huge cone filters, the one I have is maybe 6-7 inches long, I'll measure it and be sure, but will I need a bigger one?
  17. #37 Re: Need help with intake!
    I have an external MAF also and this is how mine sits.
  18. #38 Re: Need help with intake!
    USA
    A little off topic but that red on black looks pretty badass...
    So.. The filter doesn't have to be pointed to where you take off the stock filter box? Or does it
  19. #39 Re: Need help with intake!
    No...see that hole in your fender on the right when you remove the stock air box? That's basically where you want it to sit...or close to it.
  20. #40 Re: Need help with intake!
    USA
    Alright, thanks for the information. Did you have to buy any tubing for your setup or is that what was alread on it with just the cone filter added?
  1. New air intake
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2009, 02:50 AM
  2. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  3. ram air intake
    By jprovinsal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2009, 08:17 AM
  4. Intake Q
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2008, 02:35 PM
  5. intake
    By SahotaGTP in forum General Tech Discussion
    Last Post: 06-26-2008, 11:02 PM
