Thread: automatic lights suck
Results 1 to 20 of 32
  1. #1 automatic lights suck
    Illinois
    Anyone know if there is a way 2 deactivate the sensor that kicks on the lights in the dark?
  2. #2 Re: automatic lights suck
    Donating Users mystic231's Avatar
    Michigan
    Automatic lights rock That was one of the reasons i sold my SuperDuty; no auto lights. That, and it was a Ford.
    What would be the purpose of wanting to disable them?
    The Daytime Running Lights would be on anyway.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  3. #3 Re: automatic lights suck
    SE Level Member lokie81's Avatar
    Highland, IN
    Quote Originally Posted by mystic231 View Post
    Thats one of the reasons that i keep coming back to my pontiacs. I love the fact that i dont ever have to worry about turning my lights on. I do however understand why some people would like to turn them off. When i had my mustang it was fun to drive around with only parking lights and fog lights on. It kinda made the car look meaner at night IMO.
    1997 GTP Stock for the moment with long list of mods to come.
  4. #4 Re: automatic lights suck
    SE Level Member PowerStroker's Avatar
    Minnesota, Eh?
    What year Super Duty? What's wrong with Fords?
    2003 F-350 7.3L Powerstroke, hybrid (burns diesel and rubber ), lots of mods, and gets 22.5 mpg!
    2000 Grand Prix SE 3.1L
  5. #5 Re: automatic lights suck
    Wausau, WI
    Quote Originally Posted by PowerStroker View Post
    Are you serious? Do you realize that you are on a GM forum? Or, have you ever ridden in a Ford? Not only did they find the problem, they circled it.
  6. #6 Re: automatic lights suck
    Troy OH
    Quote Originally Posted by Liquifire View Post
    priceless. i'll never forget that as long as i live haha
  7. #7 Re: automatic lights suck
    Minnesota, Eh?
    I own a Ford truck and it rides like a 1-ton truck should and I love it. I also realize I'm on a GM forum. The only problems I've had with my truck (which has 210,000 miles on it) is what you'd expect from a vehicle with that many miles on it. So hop off your tuffet little miss Muffet, I'm sure your car hasn't ever been in the shop, neither has anyones on here....
  8. #8 Re: automatic lights suck
    Wausau, WI
    it is a diesel, it should go that long without major repairs. And as a superduty it should be beefed up. I am glad you have not had any major issues with it. I would expect the same from any manufacturer. I am just not a ford fan. I am sure I am not the only one on here. In my opinion, the powerstrokes suck when compared to the Cummins or the Duramax.
  9. #9 Re: automatic lights suck
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    the amount of problems that i would expect a 210k vehicle to have had depends on the make. its a ford, so.... im sorry.
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  10. #10 Re: automatic lights suck
    roselle
    year car?
  11. #11 Re: automatic lights suck
    Willoughby, Ohio
    there is a fuse in the fuse box in the glove compartment in my '99...it controls ur daytime running lights as well as automatic lights so pull it if u dnt want either...if u want just the automatic lights and to disable the daytime running lights simply unplug the wire that goes into the metal box...it can be viewed thru the compartment on the drivers side of the dashboard that get covered by the door
  12. #12 Re: automatic lights suck
    Grand Island, Nebraska
    if ur sneaking out, and u come home, you cant turn out your lights.
  13. #13 Re: automatic lights suck
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Quote Originally Posted by JoRoW99 View Post
    But....the OP is...a ninja...
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  14. #14 Re: automatic lights suck
    Highland, IN
    Quote Originally Posted by Swash View Post
    -Swash
    All i can say is LMAO !!!
  15. #15 Re: automatic lights suck
    Iowa
    To diable DRLs pop the dash cover on the sidde of the drivers side compartment. Unplug the wires from the big heat sink and you will have no DRLS,
    For the auto lights pop the cover on the dash that has the hole and small light sticking out of it. Twist the assembly on the right to get access to the light sensor. Take the sensor out and out in a 470 ohm 5% resistor (found at radio shack) and yoiu will have NO auto lights.
  16. #16 Re: automatic lights suck
    Outer Space
    Quote Originally Posted by silvermistgt2002 View Post
    I did this to my 2002, however... it didn't work. All my connections were good... but for 01+ if you cut the white wire from the BCM ... you will have no light flash on keyless, they still cut on at night though.
    02 GTP 13.6 @ 100mph - SOLD
  17. #17 Re: automatic lights suck
    Wausau, WI
    anyone ever heard of the search feature? This topic and the DRL's have been brought up about 90,845,424,328,459,745,721,375 times. That is a lot in my opinion...
  18. #18 Re: automatic lights suck
    West Side Michigan
    if you play with the switch that controls your lights and put it between the second and third setting, you can turn off your headlights, the corners will still work and you can ride around with only fog lights if you want too also. The control is the one left of the steering wheel, near the one that controls the dim setting. you can also ride around with just corners too if you wanted too.
  19. #19 Re: automatic lights suck
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Thanks for all the tips here. I was just discussing how much I despise automatic lights last night and again today, trying to figure out how to disable them.
  20. #20 Re: automatic lights suck
    SE Level Member ricardo23's Avatar
    Sonora, Mexico
    Quote Originally Posted by nawarkk View Post
    thats exactly what i do man.. works great and you dont have to take out anything.. i just took out the drl's and great.. specially when you have angel eyes and just wanna run the fog lights and the angel eyes.. like me.. i'll be posting up some pics when i get my cam back..
    00 Grand Prix SE..
    apc air filter.. nothing but.. where do we start?
  1. Has to suck to be this guy
    By BADAZGTP in forum Off Topic Discussion
    Last Post: 11-16-2008, 09:16 PM
  2. Automatic Downshifting
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2008, 08:12 PM
  3. Automatic CLimate control lights.
    By RichCresci in forum Visual/Body Modifications
    Last Post: 08-15-2008, 09:35 AM
  4. you all suck
    By chrisgtp in forum Introductions/Noob Questions
    Last Post: 01-04-2008, 08:09 PM
