if you play with the switch that controls your lights and put it between the second and third setting, you can turn off your headlights, the corners will still work and you can ride around with only fog lights if you want too also. The control is the one left of the steering wheel, near the one that controls the dim setting. you can also ride around with just corners too if you wanted too.
