Thread: automatic lights suck
Results 1 to 20 of 32
  1. #1 Re: automatic lights suck
    Wausau, WI
    Quote Originally Posted by PowerStroker View Post
    What year Super Duty? What's wrong with Fords?
    Are you serious? Do you realize that you are on a GM forum? Or, have you ever ridden in a Ford? Not only did they find the problem, they circled it.
  2. #2 Re: automatic lights suck
    Troy OH
    Quote Originally Posted by Liquifire View Post
    priceless. i'll never forget that as long as i live haha
  3. #3 Re: automatic lights suck
    SE Level Member PowerStroker's Avatar
    Minnesota, Eh?
    I own a Ford truck and it rides like a 1-ton truck should and I love it. I also realize I'm on a GM forum. The only problems I've had with my truck (which has 210,000 miles on it) is what you'd expect from a vehicle with that many miles on it. So hop off your tuffet little miss Muffet, I'm sure your car hasn't ever been in the shop, neither has anyones on here....
    2003 F-350 7.3L Powerstroke, hybrid (burns diesel and rubber ), lots of mods, and gets 22.5 mpg!
    2000 Grand Prix SE 3.1L
  4. #4 Re: automatic lights suck
    Wausau, WI
    it is a diesel, it should go that long without major repairs. And as a superduty it should be beefed up. I am glad you have not had any major issues with it. I would expect the same from any manufacturer. I am just not a ford fan. I am sure I am not the only one on here. In my opinion, the powerstrokes suck when compared to the Cummins or the Duramax.
  5. #5 Re: automatic lights suck
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Nope, you're not the only one. I'll admit, I'm a true GM fan.
    Now, we should get back on topic.
  6. #6 Re: automatic lights suck
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    cummins makes the ford diesels...
  7. #7 Re: automatic lights suck
    Apr 2009
    Quote Originally Posted by Piggy View Post
    uhmmm.... ...no
    Navistar makes the diesels for ford. Cummins engines are in dodges.
  8. #8 Re: automatic lights suck
    Cincinnati, Ohio
    sorry, u r`correct... what i meant to say was cummins could start making ford diesels... due to a partnership with navistar
  9. #9 Re: automatic lights suck
    Donating Users mystic231's Avatar
    Michigan
    Navistar used to make the diesels for Ford. Now Ford is going to try to make their own in diesels in Mexico. Good luck with that.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  10. #10 Re: automatic lights suck
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    the amount of problems that i would expect a 210k vehicle to have had depends on the make. its a ford, so.... im sorry.
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  1. Has to suck to be this guy
    By BADAZGTP in forum Off Topic Discussion
    Last Post: 11-16-2008, 09:16 PM
  2. Automatic Downshifting
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2008, 08:12 PM
  3. Automatic CLimate control lights.
    By RichCresci in forum Visual/Body Modifications
    Last Post: 08-15-2008, 09:35 AM
  4. you all suck
    By chrisgtp in forum Introductions/Noob Questions
    Last Post: 01-04-2008, 08:09 PM
