if pulling the fuse doesnt work like it didnt for me then go to radioshack and a pack of resistors for $1.they are 470-ohm, 1/4 watt 5%tolerance.
you'll need one of the resistors. where the red security light is on the dashboard the other hole has the photosensor for the autolights. carefully pop the cover off of them and take the sensor out. now take a resistor and bend the wire part and put one end into each part of the socket to make the connection. the resistor will take the place of the sensor and tell it that its light out all the time. put everything back in and your all set.
you can also make your own on/off switch with instructions here:
BACKINBLACK's Grand Prix electrical mods page...
