Thread: automatic lights suck
Results 1 to 20 of 32
  1. #1 Re: automatic lights suck
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    Quote Originally Posted by Liquifire View Post
    it is a diesel, it should go that long without major repairs. And as a superduty it should be beefed up. I am glad you have not had any major issues with it. I would expect the same from any manufacturer. I am just not a ford fan. I am sure I am not the only one on here. In my opinion, the powerstrokes suck when compared to the Cummins or the Duramax.
    cummins makes the ford diesels...
  2. #2 Re: automatic lights suck
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Quote Originally Posted by Piggy View Post
    uhmmm.... ...no
    Navistar makes the diesels for ford. Cummins engines are in dodges.
  3. #3 Re: automatic lights suck
    Cincinnati, Ohio
    sorry, u r`correct... what i meant to say was cummins could start making ford diesels... due to a partnership with navistar
  4. #4 Re: automatic lights suck
    Donating Users mystic231's Avatar
    Michigan
    Navistar used to make the diesels for Ford. Now Ford is going to try to make their own in diesels in Mexico. Good luck with that.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  5. #5 Re: automatic lights suck
    Quincy, Mass
    if pulling the fuse doesnt work like it didnt for me then go to radioshack and a pack of resistors for $1.they are 470-ohm, 1/4 watt 5%tolerance.
    you'll need one of the resistors. where the red security light is on the dashboard the other hole has the photosensor for the autolights. carefully pop the cover off of them and take the sensor out. now take a resistor and bend the wire part and put one end into each part of the socket to make the connection. the resistor will take the place of the sensor and tell it that its light out all the time. put everything back in and your all set.
    you can also make your own on/off switch with instructions here:
    BACKINBLACK's Grand Prix electrical mods page...
    No more GP 04 Impala SS Indy:
  1. Has to suck to be this guy
    By BADAZGTP in forum Off Topic Discussion
    Last Post: 11-16-2008, 09:16 PM
  2. Automatic Downshifting
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2008, 08:12 PM
  3. Automatic CLimate control lights.
    By RichCresci in forum Visual/Body Modifications
    Last Post: 08-15-2008, 09:35 AM
  4. you all suck
    By chrisgtp in forum Introductions/Noob Questions
    Last Post: 01-04-2008, 08:09 PM
