Thread: Clunking noise in front end 04 gtp!!!!
Results 1 to 17 of 17
  1. #1 Re: Clunking noise in front end 04 gtp!!!!
    SE Level Member Trump's Avatar
    Tennessee
    The clunking noise I have noticed in my 04 GTP is not in the steering Intermediate shaft, but up in the front end. Only 42 K on the car and the thump noise is noticed even going straight down a smooth road. NOT in turns or braking as much. Front end seems tight, but I will also raise it up and check things out. I raised the front end and got the wheel off the ground and started the car and put it in gear and I could hear the thump noise, seemed to be coming from the inner RH CV Joint. I replaced the CV joint and then drove the car down the road. I still hear the thump thump, but not as bad, maybe the other CV joint is bad or some bearing inside the transmission ? no idea at this time??
  2. #2 Re: Clunking noise in front end 04 gtp!!!!
    SE Level Member ibhuff's Avatar
    san diego
    I had a similar problem in my 94 grand am, which is very similar but a little different. After replacing cv joints struts and bushings it turned out to be a bad tranny mount. The fact that your getting this problem when your shifting into gear makes me wonder if it could be a tranny or motor mount.
  1. noise in front end, left side
    By Jimbo in forum Introductions/Noob Questions
    Last Post: 08-14-2009, 04:21 PM
  2. clunking noise when i go over unlevel ground
    By gotboost3 in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 07:16 PM
  3. Roar noise from front end
    By markh in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:37 AM
  4. Strange noise from front wheel
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-09-2009, 05:43 PM
  5. odd noise coming from front wheels
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 04-15-2009, 09:32 PM
