Quote Originally Posted by justin98 View Post
i can't for the life of me figure out where this clunking noise is coming form in the front end??? I have has it in and has the left outer tie rod replaced, sway bar link and the steering intermediate shaft all replaced and still does it, they can't seem to find it and two shops say that everything is tight. Anyone else have any other suggestions or experience's with this???? Also are these cars typically more road noisey it seems that my front strut mounts are rattling only 60,000 on it???? The front end clunk is when i put it in drive or reverse and start moving, going over a bump while turning and taking off from a stop and not all the time just when it wants to.
Please help!!!!
look it sounds like its the motor mounts since ur only hearing that clunk sound when u put the car on drive and reverse, i bet its when u press on the gas that the noise can be heard since im guessing ur mounts maybe bad causing ur engine to be off balance therefore causing the noise check it out it might cause u more problems in the long run, just my two cents.
