Thread: Clunking noise in front end 04 gtp!!!!
Results 1 to 17 of 17
  1. #1 Re: Clunking noise in front end 04 gtp!!!!
    Virginia
    Quote Originally Posted by justin98 View Post
    I can't for the life of me figure out where this clunking noise is coming form in the front end??? I have has it in and has the left outer tie rod replaced, sway bar link and the steering intermediate shaft all replaced and still does it, they can't seem to find it and two shops say that everything is tight. Anyone else have any other suggestions or experience's with this???? Also are these cars typically more road noisey it seems that my front strut mounts are rattling only 60,000 on it???? The front end clunk is when I put it in drive or reverse and start moving, going over a bump while turning and taking off from a stop and not all the time just when it wants to.
    PLEASE HELP!!!!
    I'm getting that exact same "clunk" noise. Sometimes in drive just starting off, sometimes when it shifts, or down shifts, going into reverse and back..Had the tires off and looked at the mounts going into drive / reverse nothing stands out. but not
    much weight on the system on jackstands and no tires....No ideas...Transmision craddle, lower mounts, upper torque struts(mounts) ? No clues....
  2. #2 Re: Clunking noise in front end 04 gtp!!!!
    SE Level Member Toxicologist's Avatar
    Albany, California
    Have you had the brake pads replaced? Does it not clunk when you have your foot on the brake?
    In my 91 Camaro, I had a "clunk" in the front end. I replaced everything steering related, and still there was a clunk. Then I realized that there was no clunk when I was braking, even if the road was bumpy. I was thinking about the problem as being associated with driving rather than not being associated with stopping. Upon inspection I noticed the brake pads didn't sit quite perfectly. I pulled them off and bent in the tabs just enough that they were tight to the calipers (and silicone the contacts). I have since come to learn that most mechanics do not adjust the tabs, and so once the silicone wears away they clunk like hell except when you are braking. I too replaced the whole front end before realizing that it could have been a free fix. I hope this helps.
  3. #3 Re: Clunking noise in front end 04 gtp!!!!
    GT Level Member hourang's Avatar
    commerce, mi
    Quote Originally Posted by Toxicologist View Post
    that must be a common 3rd gen issue, my 92 did the same thing.
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  1. noise in front end, left side
    By Jimbo in forum Introductions/Noob Questions
    Last Post: 08-14-2009, 04:21 PM
  2. clunking noise when i go over unlevel ground
    By gotboost3 in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 07:16 PM
  3. Roar noise from front end
    By markh in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:37 AM
  4. Strange noise from front wheel
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-09-2009, 05:43 PM
  5. odd noise coming from front wheels
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 04-15-2009, 09:32 PM
