Thread: Heater stopped working
Results 1 to 4 of 4
  1. #1 Heater stopped working
    GT Level Member ls1camino's Avatar
    Laurel, MD
    So yeah...it's starting to get close to freezing here in MD at when I leave for work at 6am in dress clothes for work, I'm freezing my ass off.
    I switch tstats for Summer (180*) and Winter (195*), and I just switched Friday to my Winter one. I did the usual purge of the air (opening the valve on the tstat housing while the car was warm and circulating coolant. The car now has a visibly higher temperature, per the stock gauge, but the air blows super cold (outside temp, I'm assuming). This isthe same for if the A/C is on or off. Also, it blows SUPER cold if I turn the A/C on cold. I don't have coolant in my interior, so I don't think my heater core is cracked or leaking. Do they just go bad and stop heating? Could it be clogged with crap from 11+ years? Is there a way to clean it out without ripping my dash apart? Is there a write-up for replacing a heater core?
    Thanks.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  2. #2 Re: Heater stopped working
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    it could be clogged and you can unclogg it by taking the hoses off the heater core at the fire wall and then taking a hose and blasting water through it in both directions till you get an evenly fast flow coming out both sides.
  3. #3 Re: Heater stopped working
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    Quote Originally Posted by bps02gtp View Post
    To add to this, if water does come flowing out when you spray it with a hose, you may want to take of the actual hose that goes to the heater core and make sure they are not clogged at all also
  4. #4 Re: Heater stopped working
    St. Louis
    Or, your blend door is stuck and not switching over to heat properly. Check the actuators for vacuum and see if they are still working or not.
  1. Tap shift Stopped working
    By dlemmen in forum General Tech Discussion
    Last Post: 06-16-2011, 07:29 PM
  2. Fog lights stopped working
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 04-25-2011, 09:02 PM
  3. speedometer stopped working..
    By JoeC9107 in forum General Tech Discussion
    Last Post: 03-19-2011, 06:00 PM
  4. air con stopped working
    By Tha Ghost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2011, 04:14 PM
  5. Heater stopped blowing
    By monsterjam5000 in forum General Tech Discussion
    Last Post: 07-25-2010, 11:02 AM
