Thread: How much power do i have
Results 1 to 20 of 23
  1. #1 How much power do i have
    Feb 2009
    west pittston pa
    ok i have a 03 grand prix gt 70k on the engine, i was wondering if ne 1 can give a estimate on how much hp 2 the crank and my 1/4 time... just a guess ......... mods, zzp ssm90 sc kit(billet fuel rails,machined lower intake,machined gen 3 supercharger) ,3.8 pulley,180 stat, 3inch downpipe with high flow cat,dynomax catback,autolite 103 plus,msd 8.5mm wires,gtp injectors,k&n air intake, zzp pcm 1.0 ssm90 tuning with gtp injectors... i know you wont know the exact but i just cant wait to go to the track but it doesnt open for like 2 months so if some one will just give me there guess..
  2. #2 Re: How much power do i have
    Barksdale AFB, LA
    Probably ~300 crank HP if I had to guess.
    2009 Subaru Impreza WRX STI
  3. #3 Re: How much power do i have
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by Sabrewings View Post
    You think he gained 60HP while still running the stock pulley?
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  4. #4 Re: How much power do i have
    Jersey
    my guess would be 260 to the crank and a mid to low 13 sec time with the right tires. You will never know until you try
    16' wrx sti- stock
  5. #5 Re: How much power do i have
    Waynesboro, PA
    Quote Originally Posted by 99prixgt View Post
    Low-13's with a stock pulley?!?
  6. #6 Re: How much power do i have
    Feb 2008
    Quote Originally Posted by JoshMcMadMac View Post
    This is an SSM90 GT car, so a stock sized pulley is like a GTP is on a 3.2-3.3.
    I'm going to guess 275ish. I didn't see headers or a power log. You may want to invest in a P-Log to go with your 3" DP. That'll open it up a bit!
  7. #7 Re: How much power do i have
    Barksdale AFB, LA
    Stock pulley does a hell of a lot on a top swapped car. But you're right. I thought I saw rockers or some sort of valve train mod and a Plog (aka, thinking of my mods for the top swap). More like 275-280.
    QwikGT is at nearly 300WHP on a 3.4 and an intercooler.
  8. #8 Re: How much power do i have
    Waynesboro, PA
    Wow, that almost makes me want to toss mine on the dyno to see what pops up!
  9. #9 Re: How much power do i have
    Barksdale AFB, LA
    But you're not going to see that (on that large of a pulley at least). Top swapped/ SSM90 kit cars (L36 blocks) have higher compression which means you can make more power on less boost, and that also magnifies the effects of other mods.
    Quote Originally Posted by 02BlueGT View Post
    My car is similar, and I'd guess 230 - 250 hp at the crank, but I run 15.00 at the track, so I'd say you'll run a high 14 and maybe a mid if you are really good at driving on the track.....
    Damn, I thought yours was faster than that. I can hit a low 15 (almost into the 14s) as it is right now. Top swapped it's 13s or it'll feel like a waste of money.
  10. #10 Re: How much power do i have
    Hoffman/Schaumburg, IL
    My car is similar, and I'd guess 230 - 250 hp at the crank, but I run 15.00 at the track, so I'd say you'll run a high 14 and maybe a mid if you are really good at driving on the track..... without an exhaust mod or rockers, the High compression holds timing down, which keeps us around stock GTP times until we can add more mods, QuickGT is at the level to take advantage of the high compression..... the 103's may be a little cold, I run cut back electrode 104's and have a little better MPG's
  11. #11 Re: How much power do i have
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Wait your only running 15's? What's your 60'? Because a tuned topswap car should be faster than a stockish GTP (mid to high 14's).
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  12. #12 Re: How much power do i have
    Jersey
    whoa whoa whoa 15's on your top swapped gp?!?! how much were you spinning? If i run a 15 when i get mine on, I would cry then trade it in for a honda chivic
    16' wrx sti- stock
  13. #13 Re: How much power do i have
    Quote Originally Posted by Smokin2000gtp View Post
    I was running 15.00 @ 93mph, so I had high 14 sec trap speeds, I had way too hot spark plugs (TR6xi then, now I have back cut A104's)and I had done a poor job tuning, I was just beginning to learn how to tune, I had only adjusted timing and fueling from 4k and up..... If I went to the track now, with my 100x better tune, I assume that I'd run a 14.6 or faster..... But I have basically a stock top swap, many stock GTP's run in the 14.9-15.1 range, so I don't think it was that bad.......I'll bet with a canned tune he cannot run faster than a 14.5 - 14.7, sorry, but the higher compression makes more power on the same boost, but you can only take advantage of that with more mods than an intake and a DP..... Headers, ported mani's, or a Plog will help greatly, remember a top swap is a 100% intake mod, it will only give you great gains (like into the 13's) with a decent set of supporting mods......
    With my headers, and a 3.6 or 3.5, I plan on being in the 13.8 - 14.1 range.... Hopefully this summer
  14. #14 Re: How much power do i have
    Barksdale AFB, LA
    Very true. That's why I did the LIM, SC, and TB porting first. That, combined with 1.9 rockers, and already having a plog and 2.5" DP, I'm hoping for good things.
  15. #15 Re: How much power do i have
    Waynesboro, PA
    That is what I was thinking. I know compression helps, but it is not the end-all-be-all folks seem to be making it out to be. Thank you for chiming in with the experience!
  16. #16 Re: How much power do i have
    SE Level Member 04compggtp's Avatar
    Feb 2009
    new york
    OK, all this talk about performance and 1/4 times has me interested. I have just recently finished my mods and will be going to a track about an hour away from Roch. ny. this spring/summer. With the mods in my sig. does anyone have an Idea what I might be able to run? I have changed to al 104's. I might be looking into a set of rockers also. what difference in times could I expect by adding these to my mods? From what I have read, rockers will give me more top end. That should improve 1/4 times, right? What rockers will work best for my setup? 1.8 rr or 1.9 modified? This will probably be my last engine mod, then I will start on cosmetics.
    Thrasher cai, s&b 9",zzp stainless power log, zzp 3" cated dp, :180*t stat, autolite 104's, overkill pcm,: thrasher 3.4 modular pulley,F&R drilled/slotted rotors. 245/45/18 Fierce on Casino's
  17. #17 Re: How much power do i have
    Anywhere from a 14.8 down to a 13.9 add rockers, and lower than that may be possible, it is hard to guess though, cause tires, track prep, altitude, and weather are huge factors in overall 1/4 mile time
  18. #18 Re: How much power do i have
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    With the mods in my sig plus a PRJ Tune, 3.6mps and 104's im hoping for a very very high 13. keyword is "hoping." if i dont get that im going to be dissapointed.
    theres someone on the other forum whos running a compg with only a 2.5" downpipe, Kn drop-in filter and an HP Tuners tune and it ran a 14.2
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  1. more power
    By snap on in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2009, 10:01 PM
  2. Need more N.A power
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2008, 01:32 AM
  3. tcs off = more power ??
    Last Post: 08-29-2008, 01:44 AM
  4. Need more power help!!!
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-02-2008, 09:02 PM
  5. Power Cut off
    By bburrows in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 05:07 PM
