Quote Originally Posted by Sabrewings View Post
Damn, I thought yours was faster than that. I can hit a low 15 (almost into the 14s) as it is right now. Top swapped it's 13s or it'll feel like a waste of money.
Quote Originally Posted by Smokin2000gtp View Post
Wait your only running 15's? What's your 60'? Because a tuned topswap car should be faster than a stockish GTP (mid to high 14's).
Quote Originally Posted by 99prixgt View Post
whoa whoa whoa 15's on your top swapped gp?!?! how much were you spinning? If i run a 15 when i get mine on, I would cry then trade it in for a honda chivic
I was running 15.00 @ 93mph, so I had high 14 sec trap speeds, I had way too hot spark plugs (TR6xi then, now I have back cut A104's)and I had done a poor job tuning, I was just beginning to learn how to tune, I had only adjusted timing and fueling from 4k and up..... If I went to the track now, with my 100x better tune, I assume that I'd run a 14.6 or faster..... But I have basically a stock top swap, many stock GTP's run in the 14.9-15.1 range, so I don't think it was that bad.......I'll bet with a canned tune he cannot run faster than a 14.5 - 14.7, sorry, but the higher compression makes more power on the same boost, but you can only take advantage of that with more mods than an intake and a DP..... Headers, ported mani's, or a Plog will help greatly, remember a top swap is a 100% intake mod, it will only give you great gains (like into the 13's) with a decent set of supporting mods......
With my headers, and a 3.6 or 3.5, I plan on being in the 13.8 - 14.1 range.... Hopefully this summer
