Thread: How much power do i have
Results 1 to 20 of 23
  1. #1 Re: How much power do i have
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by 02BlueGT View Post
    My car is similar, and I'd guess 230 - 250 hp at the crank, but I run 15.00 at the track, so I'd say you'll run a high 14 and maybe a mid if you are really good at driving on the track..... without an exhaust mod or rockers, the High compression holds timing down, which keeps us around stock GTP times until we can add more mods, QuickGT is at the level to take advantage of the high compression..... the 103's may be a little cold, I run cut back electrode 104's and have a little better MPG's
    Wait your only running 15's? What's your 60'? Because a tuned topswap car should be faster than a stockish GTP (mid to high 14's).
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  2. #2 Re: How much power do i have
    Jersey
    whoa whoa whoa 15's on your top swapped gp?!?! how much were you spinning? If i run a 15 when i get mine on, I would cry then trade it in for a honda chivic
    16' wrx sti- stock
  3. #3 Re: How much power do i have
    Hoffman/Schaumburg, IL
    Quote Originally Posted by Sabrewings View Post
    Damn, I thought yours was faster than that. I can hit a low 15 (almost into the 14s) as it is right now. Top swapped it's 13s or it'll feel like a waste of money.
    Quote Originally Posted by Smokin2000gtp View Post
    Quote Originally Posted by 99prixgt View Post
    I was running 15.00 @ 93mph, so I had high 14 sec trap speeds, I had way too hot spark plugs (TR6xi then, now I have back cut A104's)and I had done a poor job tuning, I was just beginning to learn how to tune, I had only adjusted timing and fueling from 4k and up..... If I went to the track now, with my 100x better tune, I assume that I'd run a 14.6 or faster..... But I have basically a stock top swap, many stock GTP's run in the 14.9-15.1 range, so I don't think it was that bad.......I'll bet with a canned tune he cannot run faster than a 14.5 - 14.7, sorry, but the higher compression makes more power on the same boost, but you can only take advantage of that with more mods than an intake and a DP..... Headers, ported mani's, or a Plog will help greatly, remember a top swap is a 100% intake mod, it will only give you great gains (like into the 13's) with a decent set of supporting mods......
    With my headers, and a 3.6 or 3.5, I plan on being in the 13.8 - 14.1 range.... Hopefully this summer
  4. #4 Re: How much power do i have
    Barksdale AFB, LA
    Very true. That's why I did the LIM, SC, and TB porting first. That, combined with 1.9 rockers, and already having a plog and 2.5" DP, I'm hoping for good things.
    2009 Subaru Impreza WRX STI
  5. #5 Re: How much power do i have
    That combo, I could see getting into the 13's, While scanning, I can actually see when my Exhaust becomes a restriction (3320 RPM roughly on my motor) I believe with exhaust work, there is a lot to be had with the top swap without having to use small pullies
  6. #6 Re: How much power do i have
    Barksdale AFB, LA
    I'm starting on the 3.8" and going to see how tuning goes. It's modular, so swapping to another size is cake.
  7. #7 Re: How much power do i have
    Nice, after my headers go in(they have been in my room since early January) I'm gonna get a modular hub, and try a 3.6, and maybe a 3.5 pulley, we will see how well my motor likes the headers
  8. #8 Re: How much power do i have
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    That is what I was thinking. I know compression helps, but it is not the end-all-be-all folks seem to be making it out to be. Thank you for chiming in with the experience!
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  9. #9 Re: How much power do i have
    Quote Originally Posted by JoshMcMadMac View Post
    No prob ...... I gained .8 from my last track outing, so my car is much faster than it was.... just not 13's fast yet
  1. more power
    By snap on in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2009, 10:01 PM
  2. Need more N.A power
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2008, 01:32 AM
  3. tcs off = more power ??
    Last Post: 08-29-2008, 01:44 AM
  4. Need more power help!!!
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-02-2008, 09:02 PM
  5. Power Cut off
    By bburrows in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 05:07 PM
