So I did swap injectors 3 & 5. No change. I believe it would be worth checking resistance on the signal wires for injectors 3 & 6. I just need to dig up a wiring diagram.
I mean, I did a visual inspection and everything looks good. Didn't see any obvious missing grounds or chaffed wires. I triple checked that the plug wires are in the right spots. Even printed out a cheat sheet. Maybe I'll swap 3 & 6 just for grins.except of course grounds which I assume you verified, along with firing order.
Or broken valve springs? Then again, zero misfires at idle...I don't know that cranking pressure would tell you anything unless there's stuck valves.
Great question! Those plugs looked exactly like the other 4. Kind of like a toasted marshmallow. Light brown. No crust. No soot.What did the plugs from those holes say?
Agreed. I haven't let it run long enough to go into closed loop.I would think comparison to healthy fuel trims might offer a hint.
Worth a shot I suppose. So strange that it only misfires on 3 & 6 though.Connecting an analog (plain old regular) vacuum gauge would point out a manifold or valve problem.
Nope, I appreciate the feedback. Gets me thinking in multiple directions.I do know I am not fit to advise but one reply beats none.
