Thread: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
Results 1 to 19 of 19
  1. #1 P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Mar 2014
    Tucson
    So here's the story. I recently purchased a 2001 Regal GS with a P0300 (random misfire) code. Misfires only showed on 3 & 6. I got it for a decent price because of the code and I figured it would be a simple fix. Misfire on 3 & 6... Must be a coil.
    Wrong!
    Let's step back to the original diagnosis procedure. Car idles great. ZERO misfires at idle. When I wind it up to 2k rpm, HPT starts counting misfires by tens on 3 & 6.
    1.) I swapped the coils around. Misfires stay on 3 & 6. I figure it must be the ICM.
    2.) I replace the ICM with a brand new Delphi unit. Still misfires on 3 & 6.
    3.) I replace plugs and wires. Still misfires on 3 & 6.
    4.) I swap injectors 3 & 5. Still misfires on 3 & 6.
    5.) I tested for 12v at #3 injector with the key on. Lit a test light nice and bright.
    6.) 12v test light on the #3 injector connector barely pulses. Very faint light. However, it is the exact same intensity as #5.
    Not sure where to go from here. Maybe a compression test? What that will tell me? Again, zero misfires at idle, no excessive blowby, and it's still on a stock pulley.
    Rapid fire: What to I check next?
    7.) CASE relearn done. Still misfires on 3 & 6 (P0300) with and additional P0303 (misfire on #3) code.
    *Edit. CASE relearn fixed it. Read on for details.
  2. #2 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Jan 2014
    AR
    Sounds like injector wiring (or injectors, maybe swap those around, too?) is the only thing left, except of course grounds which I assume you verified, along with firing order. Plug wires can be hooked up all wrong and due to the design, a guy may never notice. I don't know that cranking pressure would tell you anything unless theres stuck valves. What did the plugs from those holes say? I would think comparison to healthy fuel trims might offer a hint. Connecting an analog (plain old regular) vacuum gauge would point out a manifold or valve problem.
    I do know I am not fit to advise but one reply beats none.
  3. #3 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Mar 2014
    Tucson
    Quote Originally Posted by idrivejunk View Post
    So I did swap injectors 3 & 5. No change. I believe it would be worth checking resistance on the signal wires for injectors 3 & 6. I just need to dig up a wiring diagram.
    I mean, I did a visual inspection and everything looks good. Didn't see any obvious missing grounds or chaffed wires. I triple checked that the plug wires are in the right spots. Even printed out a cheat sheet. Maybe I'll swap 3 & 6 just for grins.
    I don't know that cranking pressure would tell you anything unless there's stuck valves.
    Or broken valve springs? Then again, zero misfires at idle...
    Great question! Those plugs looked exactly like the other 4. Kind of like a toasted marshmallow. Light brown. No crust. No soot.
    Agreed. I haven't let it run long enough to go into closed loop.
    Worth a shot I suppose. So strange that it only misfires on 3 & 6 though.
    Nope, I appreciate the feedback. Gets me thinking in multiple directions.
  4. #4 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Kemmerer, Wyoming
    could it be the O2 sensor or Maf?
  5. #5 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    got to be a bad wire. off the icm or to the injectors. check that metal harness loop on the do bone. see if theres any damaged wires inside that area.
  6. #6 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Mar 2014
    Tucson
    Quote Originally Posted by SgtMarshal View Post
    I mean, I really don't think so with the misfire isolated to 3 & 6 only.
    I'm leaning toward this. Especially on the spark side of the equation. I just can't get past the fact that 3 & 6 share a coil. It is just too convenient to be anything else in my mind. Especially since the misfires on 3 & 6 are pretty much equal. Within 10% I'd say. I'm seeing if I can find some diagrams for the PCM and ICM. I'll do some resistance checks and peel back some wire loom.
    I'm thinking the control wire for the 3/6 coil is chafed and/or missing a bunch of strands somewhere. Enough remains that everything is fine at idle, but can't handle any kind of load like higher RPM. That's my current theory anyway. Probably won't know anything till next weekend. I only have time to mess with it between 60e builds. Gotta rake hay while the sun is shining.
  7. #7 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Apr 2014
    commerce twp,mi
    a broken valve spring wouldnt cause a RANDOM misfire,would it?
    08 grand prix NA3800
  8. #8 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    GT Level Member mguzzo's Avatar
    Buffalo NY
    i was wondering the chances that Chip has visited you twice.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  9. #9 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Mar 2014
    Tucson
    Quote Originally Posted by tomsteve View Post
    I mean, random as defined by the PCM. I'm not sure what the exact parameters the PCM needs to see to set the MIL.
    Quote Originally Posted by mguzzo View Post
    You shut your mouth with that negativity!
  10. #10 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Buffalo NY
    dumb question, are you sure that 3 is going to 3 and 6 to 6?
  11. #11 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Mar 2014
    Tucson
    Valid question. Correct me if I'm wrong... #3 wire is going to the center cylinder on the front bank. #6 wire is going to the furthest left (drives side) cylinder on the rear bank.
  12. #12 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    back
    246
    135
    front
  13. #13 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Doesn't actually matter. Since the packs are 1/4, 2/5 and 3/6. Both towers of each coil fire at the same time. Hence the term waste spark system. One spark is always wasted during the exhaust stroke the other goes to the other cylinder for detonation. 3/6 would fire both at same time.
    Since it's mad only on that coil and you've swapped coils, wires, plugs and ICM, try a crank learn. I know it seems like it's not needed and you'd never consider it. I've seen some really odd behavior and typically a crank relearn did the trick. Had a few that started and ran horrible, you check everything and can't find anything.. crank learn and it purrs. Can't hurt to try.
  14. #14 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Mar 2014
    Tucson
    ...try a crank learn. ... Can't hurt to try.
    You're absolutely correct. I had enough time this evening to do just that. Unfortunately didn't change anything. Going to order a noid light kit and if I get time tomorrow I'll do a closer visual check of all the wires.
  15. #15 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    You know.. you can just pull a 194 bulb out.. straighten the tabs and use that
  16. #16 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    i hipped him to that trick in da chat......
  17. #17 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Mar 2014
    Tucson
    Quote Originally Posted by BrandonHall10 View Post
    Once again Bill is spot on. Apparently I wasn't doing something correctly. Had a buddy do the CASE relearn with a pro scan tool. As soon as he did that... ZERO misfires. Going to put some miles on it now and report back, but as of right now all is well. Hope I'm not speaking too soon.
  18. Likes Scottydoggs liked this post
  19. #18 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    GTP Level Member
    Oct 2014
    Have to love Bill!
  20. #19 Re: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    More like got lucky again.
    In the past I had a couple of cars I worked on and they just wouldn't run good for anything from start up. You check over everything and you wonder.. what happened???? Tried a crank relearn and sure enough the engine purrs. Only thing I can think of is that the pcm etc is off on it's information and the relearn straightens it up. Kinda like a pc reboot.
    Happy to hear it's running good.
  1. P0300 Random Misfire figured out.
    By swtnlow1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-02-2017, 09:39 PM
  2. P0300 - Random Multiple Cylinder Misfire
    By J7319M in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2013, 09:20 PM
  3. p0300 random misfires
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2013, 09:44 PM
  4. P0300 Code. Random Misfire NEED HELP!
    By JcGTP39 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2011, 10:12 PM
  5. random misfire P0300, many new parts
    By MarkB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2009, 11:10 PM
