Thread: P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
Results 1 to 19 of 19
Threaded View
  1. #1 P0300 (Random misfire) Shows on 3 & 6 only. looking for help.
    Mar 2014
    Tucson
    So here's the story. I recently purchased a 2001 Regal GS with a P0300 (random misfire) code. Misfires only showed on 3 & 6. I got it for a decent price because of the code and I figured it would be a simple fix. Misfire on 3 & 6... Must be a coil.
    Wrong!
    Let's step back to the original diagnosis procedure. Car idles great. ZERO misfires at idle. When I wind it up to 2k rpm, HPT starts counting misfires by tens on 3 & 6.
    1.) I swapped the coils around. Misfires stay on 3 & 6. I figure it must be the ICM.
    2.) I replace the ICM with a brand new Delphi unit. Still misfires on 3 & 6.
    3.) I replace plugs and wires. Still misfires on 3 & 6.
    4.) I swap injectors 3 & 5. Still misfires on 3 & 6.
    5.) I tested for 12v at #3 injector with the key on. Lit a test light nice and bright.
    6.) 12v test light on the #3 injector connector barely pulses. Very faint light. However, it is the exact same intensity as #5.
    Not sure where to go from here. Maybe a compression test? What that will tell me? Again, zero misfires at idle, no excessive blowby, and it's still on a stock pulley.
    Rapid fire: What to I check next?
    7.) CASE relearn done. Still misfires on 3 & 6 (P0300) with and additional P0303 (misfire on #3) code.
    *Edit. CASE relearn fixed it. Read on for details.
  1. P0300 Random Misfire figured out.
    By swtnlow1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-02-2017, 09:39 PM
  2. P0300 - Random Multiple Cylinder Misfire
    By J7319M in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2013, 09:20 PM
  3. p0300 random misfires
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2013, 09:44 PM
  4. P0300 Code. Random Misfire NEED HELP!
    By JcGTP39 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2011, 10:12 PM
  5. random misfire P0300, many new parts
    By MarkB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2009, 11:10 PM
