Thread: P0300 Random Misfire figured out.
Results 1 to 15 of 15
  1. #1 P0300 Random Misfire figured out.
    Mar 2015
    Indiana
    After weeks of changing parts and scratching my head, I found the cause of my random misfire. I went to change the harmonic balancer and crank sensor, and after removing the balancer, I found that the screws holding the reluctor ring on were loose. I applied Loctite to the screws and retightened them, and like magic, the misfire was gone. Took about 30 minutes. This is a free check, and beats spending money chasing a ghost. I have seen a lot of people struggling with this problem, and I sure hope this helps someone. Wish I had found it sooner.
  2. #2 Re: P0300 Random Misfire figured out.
    GXP Level Member
    Mar 2015
    Tomball
    That's interesting for sure I'm surprised it didn't take out the crank sensor. Must not have been very loose?
  3. #3 Re: P0300 Random Misfire figured out.
    hangover park IL
    it was probably replaced with a dorman balancer, ive had to swap the tone wheels over, though now I think they come with them
    ~James~ Psychotic Gearhead
  4. #4 Re: P0300 Random Misfire figured out.
    Mar 2015
    Indiana
    Not sure of the history, but the balancer that I bought to replace it had 4 screws in it, the one on the car only had two. After several weeks of driving, I still have not had any misfire codes come back up.
  5. #5 Re: P0300 Random Misfire figured out.
    Mar 2015
    Indiana
    The screws were just loose enough for the rings to rotate, not really wobble, guess I got lucky on that one.
  6. #6 Re: P0300 Random Misfire figured out.
    Mar 2015
    Indiana
    After 2 months of driving, still no new misfire codes, just wanted to give an update.
  7. #7 Re: P0300 Random Misfire figured out.
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    I assume the reluctor ring is on the balancer?
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  8. #8 Re: P0300 Random Misfire figured out.
    GXP Level Member
    Mar 2015
    Tomball
    Excellent info.
    Yeah it's on the back of the balancer.
  9. #9 Re: P0300 Random Misfire figured out.
    Feb 2008
    NY
    Thx. I have a power Bond SFI balancer. Gonna pull it off and check.
  10. #10 Re: P0300 Random Misfire figured out.
    Sal still chasing down that misfire are ya?
  11. #11 Re: P0300 Random Misfire figured out.
    Feb 2008
    NY
    Lol. Yes I am. I've changed and upgraded just about everything.
    I might even put back stock balancer just to rule out SFI one.
    Next is starting from complete scratch with a new tune. If not that then I'll have to pull engine out
  12. #12 Re: P0300 Random Misfire figured out.
    hangover park IL
    so, his misfire at 15psi may have been figured out...but since I don't have bookface I wont know til Sal does another couple tests/visual inspection
  13. #13 Re: P0300 Random Misfire figured out.
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Wahaaaat? Give us the details
    Sent from my SM-G930V using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  14. #14 Re: P0300 Random Misfire figured out.
    hangover park IL
    ive been having him work through a few tests, we'll see how the recent tests work but its likely lean on #2 due to the air path
  15. #15 Re: P0300 Random Misfire figured out.
    Dec 2008
    ****'s Creek
    We were thinking possible crack in head or block on #2. What do you mean by air path. the longest distance through the intake?
  1. P0300 - Random Multiple Cylinder Misfire
    By J7319M in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2013, 09:20 PM
  2. p0300 random misfires
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2013, 09:44 PM
  3. P0300 Code. Random Misfire NEED HELP!
    By JcGTP39 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2011, 10:12 PM
  4. Random Misfiring P0300 Code
    By spcguy88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2010, 09:44 PM
  5. random misfire P0300, many new parts
    By MarkB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2009, 11:10 PM
