Thread: brake caliper bracket, new or re-bushed (reman)?
Results 1 to 2 of 2
  1. #1 brake caliper bracket, new or re-bushed (reman)?
    Nov 2016
    N. California
    The caliper bracket on my 2001 GTP feels very loose in the guide pin bores. It doesn't just slide in and out as a floating caliper should, it rocks excessively as though the bores in the caliper bracket for the guide pins are worn out. Of course the guide pins are fine. The calipers are NAPA "reman", so probably just a new piston seal, dust boot, guide pins and rattle-can spray job. Pardon my cynicism. Clearly they did not bore and re-bush the caliper bracket guide pin bores.
    I see we can no longer buy caliper brackets new from GM, but I can buy "reman" caliper brackets from the usual snake oil salesmen. What exactly does "reman" mean; rattle can spray paint job and a shiny cardboard box?
    The complaint is a faint but annoying high-pitched squeal rolling down the road, goes away with application of the brakes. I have affected it to some extent by greasing the pad backs, pad guides and caliper guide pins, but it doesn't really cure the problem. Pretty sure those calipers shouldn't be mounted in sloppy bracket bores.
    Anybody here have experience buying a reman bracket where they actually bushed the bores?
    Thanks,
    Lifespeed
    2001 GTP
  2. #2 Re: brake caliper bracket, new or re-bushed (reman)?
    Nov 2016
    N. California
    I see boots/bushings are offered for sale. They look like plastic. I could install a set of these, although surely they were new from NAPA. But if they're plastic all bets are off as to any longevity . . .
    Is it normal for these calipers to rock side-to-side just using my hand? Maybe the caliper is a little sticky.
    Lifespeed
    2001 GTP
  1. Replies: 7
    Last Post: 11-09-2016, 11:29 AM
  2. Rubbing on the Caliper Bracket???
    By CameronMRich in forum Tires & Wheels
    Last Post: 03-22-2014, 03:56 PM
  3. GXP Brake Caliper Bracket bushing
    By Spartan GL in forum Brakes/Suspension/Chassis
    Last Post: 06-05-2011, 04:43 PM
  4. caliper bracket
    Last Post: 08-16-2009, 02:04 PM
  5. caliper bracket
    By gotboost3 in forum Brakes/Suspension/Chassis
    Last Post: 02-11-2009, 08:44 PM
