Thread: Wiring diagram, 2000 GTP
Results 1 to 5 of 5
  1. #1 Wiring diagram, 2000 GTP
    Oct 2013
    Dillon MT
    Do any of you have a wiring diagram for said car? I'm going to try to diagnose my EGR not getting power. I already know the valve works, it's just not getting power from the computer. The control signal is there, but no power to the motor. I bought a wire tracer to try to track down a break in the wire, but need to know which pin it should be on the computer end of the harness.
    Sent from my Moto E (4) Plus using Tapatalk
  2. #2 Re: Wiring diagram, 2000 GTP
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I do have the service manual, but I usually am lazy and use autozone. Create a free account and link your vehicle as your selected model. Go to repair help tab>Vehicle Repair Guides>Wiring Diagrams. Use the left hand side to select what you're looking for. Has pretty much every diagram in the service manual. To print it out, just right click and save as image, then open and print! Enjoy!
  3. Thanks skills4lou thanked for this post
  4. #3 Re: Wiring diagram, 2000 GTP
    Oct 2013
    Dillon MT
    So I'm still working on figuring this P0401 code out. Here's where I'm at so far: I found the following link: Part 6 -How To Test the GM EGR Valve -Buick, Chevy, Olds, Pontiac
    I worked my way through all of them, and it passed everything with one small exception. The wire labeled "E" does have 12V, but only while the connector is disconnected. As soon as I plug it back into the EGR valve the power drops to ~0.03V. I'm stumped. There is no carbon blocking anything, and when I try to start it with the valve off it stalls immediately. All other tests are within limits.
    Of course, to add insult to injury the brand new CV axle that I installed in February has a cracked boot and puked grease everywhere, so I'll have to do that damn thing again. I'm ready to sell this car.
  5. #4 Re: Wiring diagram, 2000 GTP
    Is that insufficient flow?
    If it is.. research the map sensor as it reads the expected change in flow. If the map is bad.. you can get the insufficient code.
  6. #5 Re: Wiring diagram, 2000 GTP
    Oct 2013
    Dillon MT
    Yes, insufficient flow.
    I'll look into the MAP sensor. Thanks!
  1. 2000 Grand Prix Bose wiring diagram, woofers work, 6x9's not turning on
    By Xanthous in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2015, 08:21 AM
  2. 98 GP wiring diagram
    By AKGTP19 in forum General Grand Prix Discussion
    Last Post: 01-08-2014, 11:36 AM
  3. Replies: 0
    Last Post: 07-19-2012, 07:16 PM
  4. Wiring Diagram?
    By Adidasdude1989 in forum General Tech Discussion
    Last Post: 06-23-2012, 06:30 PM
  5. wiring diagram for 96 SE?
    By 3100sfi in forum Audio, Security & Visual Electronics
    Last Post: 07-08-2011, 08:16 PM
