Thread: Quick trans identification question.
Page 3 of 3 FirstFirst 123
Results 41 to 42 of 42
  1. #41 Re: Quick trans identification question.
    SE Level Member james782004's Avatar
    Nov 2015
    They are good cars, if you get one that has been taken care of. My gtp needs a bit of tlc, but with 166k miles I'll fix it and see what it looks like after 😆
    Sent from my SM-G920R4 using Tapatalk
  2. #42 Re: Quick trans identification question.
    GT Level Member sampuppy1's Avatar
    Mar 2016
    238k on this one. Needs struts bad all around. Brakes soon. Some rot. Maybe I'll have it repaired maybe not. Depends on cost. I like that it has leather. I like that it runs good. Which reminds me I'm due to change the oil filter and add a quart of trans fluid and go drive around for the rest of this tank. The oil system is super gunky. So I switched it to full synthetic before the first fire up. Figured a thousand miles should get all the big gunk trapped in the cheap filter, another cheap filter and some high detergent full synthetic trans fluid will get the really hard to clean crap out and then one more cheap filter for 1k miles to make sure any leftovers get picked up. It's my #1 process for cleaning up a used engine internally without taking it apart. It worked on my truck
    Sent from my XT1254 using Tapatalk
  1. Need answer ASAP quick question on 04+ trans compatibility
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-10-2015, 07:46 PM
  2. Quick Question
    By Matthew Mericle in forum Introductions/Noob Questions
    Last Post: 10-28-2012, 11:57 PM
  3. Quick help please! Just a quick question!
    By nikkigpgt00 in forum Tires & Wheels
    Last Post: 07-31-2012, 12:29 PM
  4. Quick trans Overhaul
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-11-2009, 08:21 AM
  5. Quick Question
    By High Rolling GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2009, 01:13 PM
