Thread: Quick trans identification question.
Results 1 to 20 of 42
  1. #1 Re: Quick trans identification question.
    GT Level Member sampuppy1's Avatar
    Mar 2016
    There is a bushing/bearing that partially covers that section of splined so I was thinking it had something to do with fluid delivery to said bearing/bushing.
    I've heard the forward band is a common thing. Since I'm doing one I might as well do the other two......
    Good to know the lube dam is a simple and cheap part.
    Any other trouble areas I should look at while I've got it all apart?
    Any suggestions as to where I should get parts maybe online? ZZP is local to me and I know they have made quite a name for themselves but I'm not sure if they carry trans parts.
    Also the valvebody is the only thing I could see being a struggle for me. The little ball valves. A few fell out while I was cautiously (obviously not cautious enough haha) taking it apart. I did recover all of them from the drain pan and I believe I found all their proper locations in both sides of the valve body. But just for good measure is there some sort of valvebody map that would point out in a diagram where these little bastards go? I'm picking up a small tub of asemblee lube. Figure a small dab would keep them in place while I mate the two halves of the valve body assembly together and it'll break down upon the first drive correct?
    The plastic insert in between the two halves of the valve body.... Get a new one? Seems like its a gasket of sorts.
    Sent from my XT1254 using Tapatalk
  2. #2 Re: Quick trans identification question.
    Mar 2014
    Tucson
    Quote Originally Posted by sampuppy1 View Post
    A couple.*
    Find a Transtar store. There's one in Grandville. Otherwise, just get from wherever. It's all the same stuff. I wouldn't get anything from ZZP though. They just upcharge for stock stuff you can get anywhere. (Speaking only about trans stuff. Not throwing stones)
    I would highly recommend doing the full Trans-Go kit, since you have it all blown apart.
    *Get your hands on an ATSG manual and give it a read through. This will show you any areas of concern. As well as check ball location and torque specs for everything. It will save you a ton of frustration.
  1. Need answer ASAP quick question on 04+ trans compatibility
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-10-2015, 07:46 PM
  2. Quick Question
    By Matthew Mericle in forum Introductions/Noob Questions
    Last Post: 10-28-2012, 11:57 PM
  3. Quick help please! Just a quick question!
    By nikkigpgt00 in forum Tires & Wheels
    Last Post: 07-31-2012, 12:29 PM
  4. Quick trans Overhaul
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-11-2009, 08:21 AM
  5. Quick Question
    By High Rolling GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2009, 01:13 PM
