Thread: Replace lines on steering rack
Results 1 to 4 of 4
  1. #1 Replace lines on steering rack
    Mar 2016
    Rochester, NY
    I need to replace the two small metal lines on the steering rack, but I cannot find them anywhere. Can I just make new ones with brake lines? If so what kind of flare are they?
  2. #2 Re: Replace lines on steering rack
    St. Louis
    Check rockauto.com for the power steering lines. Shouldn't be that expensive and will work better than homemade lines. If they don't have any then check Autozone, OReilley's, etc.
  3. #3 Re: Replace lines on steering rack
    GXP Level Member
    Mar 2015
    Tomball
    He's talking about rack lines not the ones for the power steering pump. I'm not sure what size flare they are but I know a compression fitting will fail in short order...
    Jeff
  4. #4 Re: Replace lines on steering rack
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I had the same problem I just ended up putting a new rack in.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  1. I had to replace the Rack & Pinion assembly on my 01 GP GT
    By GT in Kennesaw in forum Brakes/Suspension/Chassis
    Last Post: 03-29-2014, 01:14 PM
  2. Anyway to repair Rack & Pinion hard lines?
    By GTPlzz in forum General Tech Discussion
    Last Post: 11-18-2013, 04:16 PM
  3. Cradle is dropped, should I replace my PS rack while I'm there?
    By SJAndrew in forum General Tech Discussion
    Last Post: 08-09-2012, 10:14 PM
  4. Replace Magnasteer Rack with Regular Rack?
    By Smoker324 in forum General Tech Discussion
    Last Post: 06-29-2010, 09:11 PM
  5. 97 GTP Steering Rack Replace
    By PolishedandWaxed in forum Brakes/Suspension/Chassis
    Last Post: 09-09-2009, 09:42 PM
