Thread: Is a SSIC worth it?
Results 21 to 40 of 69
  1. #21 Re: Is a SSIC worth it?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by SgtMarshal View Post
    that makes no sense at all
    Something to do with pump failure causing it to go lean an blow up idk like I said I don't know alot about a methanol kit
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #22 Re: Is a SSIC worth it?
    that meth kit for this car beings its ssm90 is quite possibly the best idea marshal has had his entire life lol.
    its even cost effective and less of a pain in the dick than an intercooler.
    meth > short stack thats for damn sure.
    full size maybe a different story but vs a short stack go meth
  3. #23 Re: Is a SSIC worth it?
    Jul 2015
    Jamestown, NY
    What do I need to do for a methanol kit? Injectors and fuel pump?
  4. #24 Re: Is a SSIC worth it?
    Mercer, Pa
    I'm kind of partial to Intercoolers. They make HP and are the one of the best ways to get more power out a M90.
    E85 is great if you have it.
  5. #25 Re: Is a SSIC worth it?
    obviously partial to intercoolers..... short stack nahhhh do meth instead.
  6. #26 Re: Is a SSIC worth it?
    Quote Originally Posted by Tonkin2000GT View Post
    Lol Scotty I'm running about the same pulley as you and you have a fsic? Wacked
    your cam is the help. rockers are nice but dont flow as good as a cam. stock pulley i was seeing 6.5 boost, stock lim and gen 3, now ported lim ic and the 3.2 like 9 psi.
    hit 12 with the 2.8 when i tried that one out for a while. that was knock free but it was also cold out. and i had to drop to much timing to run it too. so im back on the 3.2 till summer, then ill see what pulley i can run best in the heat of summer.
    i got 5 pulleys to play with, 3.4 3.2 3.0 2.8 and 2.6 that will never be used lol
  7. #27 Re: Is a SSIC worth it?
    Jul 2015
    Jamestown, NY
    Yea everyone says no to a ssic zzp said it's better then no intercooler I just don't know if it's worth the gains is kinda why I haven't done it yet
  8. #28 Re: Is a SSIC worth it?
    Kemmerer, Wyoming
    you don't need bigger injectors or an upgraded fuel pump for methanol. if a fuel pump is going to fail, it will fail in the summer or winter. you need to learn to get information from other sources than zzp. that methanol kit for sale on the classifieds is complete. all you need to do is install it, fill the reservoir with methanol and go. some people say to lean the air fuel ratio, other people say not to, because when you inject methanol, your air fuel ratio will go rich.
  9. #29 Re: Is a SSIC worth it?
    Kemmerer, Wyoming
    what happened to the 3.0?
  10. #30 Re: Is a SSIC worth it?
    quick question, do they make a ssm98 pulley smaller then a 3.4? iirc they dont get to small. looks like they hit the snout faster being they are off set.
  11. #31 Re: Is a SSIC worth it?
    Jul 2015
    Jamestown, NY
    Yeah but my heads are ported ALOT, it's bored .020 over, zzp inlet and outlet porting to my gen 3 made it about a gen 5, and the motor is fresh I have a 3.4 and can probably go to a 3.3 with 18° timing 0kr
  12. #32 Re: Is a SSIC worth it?
    Jul 2015
    Jamestown, NY
    Lol I'm not running it on the serpentine belt it's setup like a gtp I'm using a SFI crank pulley 8 rib belt I didn't buy zzp's kit for that reason
  13. #33 Re: Is a SSIC worth it?
    good move lol
  14. #34 Re: Is a SSIC worth it?
    Jul 2015
    Jamestown, NY
    So I'm interested on more info on meth kits and what I'll have to do?
  15. #35 Re: Is a SSIC worth it?
    being you have a N*, you would drill and tap that adapter plate and put the spray nozzle in there. thats the hard part.
  16. #36 Re: Is a SSIC worth it?
    Mercer, Pa
    Is the SFI pulley 5% bigger
  17. #37 Re: Is a SSIC worth it?
    Jul 2015
    Jamestown, NY
    Nope stock size
  18. #38 Re: Is a SSIC worth it?
    Jul 2015
    Jamestown, NY
    Okay seems pretty easy so the meth tank is separate you mount it in the trunk how much meth does it hold? How much do you actually use? I'm assuming there are different jets or nozzles? What kinda gains? Pulley drop?
  19. #39 Re: Is a SSIC worth it?
    Buffalo
    When you have to choice to pick FS or SS , it's retarded to choose the SS. When your only choice is none or SS. Then I say SS
  20. #40 Re: Is a SSIC worth it?
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by CrazyGuy03 View Post
    Yeah what do you think about a methanol kit instead?
  1. ssic
    By oneredi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2012, 03:40 PM
  2. Ssic
    By boothe in forum Wanted To Buy - Parts
    Last Post: 02-29-2012, 10:55 PM
  3. Is it worth it to put more money into the car than what its worth?
    By xander37 in forum General Tech Discussion
    Last Post: 01-17-2012, 06:28 AM
