Thread: Is a SSIC worth it?
Results 41 to 60 of 69
  1. #41 Re: Is a SSIC worth it?
    Buffalo
    Could not offer any advice. I never used it / didn't need to with either cam, rockers , pulley sizes or IC. I've always based my tune around my mods
  2. #42 Re: Is a SSIC worth it?
    2 words
    DOOOOOOOO ETT
  3. #43 Is a SSIC worth it?
    Mercer, Pa
    Meth
    Never found anyone saying I've used it for years and it works great.
    I've used FSIC for years and they work great.
  4. #44 Re: Is a SSIC worth it?
    wheres the clearance issue with a fsic and a ssm90 set up?
    if its the injectors cant the core be ground down some to clear it, kinda like what they do to the blower?
  5. #45 Re: Is a SSIC worth it?
    mr. IC leg humper in case you havnt noticed he CANT use a fullsize...............
  6. #46 Re: Is a SSIC worth it?
    im asking why?
  7. #47 Re: Is a SSIC worth it?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Zzp said they have tried everything possible they can get the injectors in but the angle they are on you can't get it to idle right I guess
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  8. #48 Is a SSIC worth it?
    Mercer, Pa
    On a ssm90 the injectors occupy the space needed for the Intercooler core.
    The shorts stack core is thinner and smaller and leaves room for the injectors also making its performance value smaller.
  9. #49 Re: Is a SSIC worth it?
    not you scott lol.....
    because nitrous isn't used very often and people don't post results on nitrous setups very often does that mean it doesn't work?
  10. #50 Re: Is a SSIC worth it?
    Mercer, Pa
    Quote Originally Posted by Vet View Post
    I'm a leg humper because I've used Intercoolers and they work!
  11. #51 Re: Is a SSIC worth it?
    Mercer, Pa
    Please educate us. If you run meth injection on a daily driver and it works great.
    I try not to give advice if I don't no anything about it.
  12. #52 Re: Is a SSIC worth it?
    I can't think of his name atm, but the guy that bought adeckers old 04 did he at one time run a fsic with the ssm90 setup?
    04 Comp G.
  13. #53 Re: Is a SSIC worth it?
    Frosty
  14. #54 Re: Is a SSIC worth it?
    Frosty
    Snowth1ef
    04 Comp G.
  15. #55 Re: Is a SSIC worth it?
    dunno about him but this dude has a gen5 on a ssm90 setup......
    Soooo gee um iff a gen5 fits im pretty sure a full size ic would fit by following this....
    Has pics even.
    Damn miracle when a person uses the search.....
    http://www.grandprixforums.net/threa...-wouldent-work
  16. #56 Re: Is a SSIC worth it?
    Jul 2015
    Jamestown, NY
    Lol no it has nothing to do with a intercooler zzp machined the outside of my gen 3 case to fit for the injectors also you can't cut into the core that much without ruining it
  17. #57 Re: Is a SSIC worth it?
    what i was saying, dont see why you cant just clearance the core for the injectors. a 1/2 area here and there should not hurt any thing.
  18. #58 Re: Is a SSIC worth it?
    Jul 2015
    Jamestown, NY
    Zzp said they tried they have ruined several intercoolers doing it I guess there isn't alot of room to grind anything off without getting into a coolant passage
  19. #59 Re: Is a SSIC worth it?
    Jul 2015
    Jamestown, NY
    I don't know I'm not arguing just what I was told I wish someone has done it and informs me lol
  20. #60 Re: Is a SSIC worth it?
    looking at this pic you'd have to take a nice chunk out of the core. another reason for l67 heads.
    this is my ic on a l67 lim and the rails laid on, it does look to be a ton of meat that could be dug into on the core.
  1. ssic
    By oneredi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2012, 03:40 PM
  2. Ssic
    By boothe in forum Wanted To Buy - Parts
    Last Post: 02-29-2012, 10:55 PM
  3. Is it worth it to put more money into the car than what its worth?
    By xander37 in forum General Tech Discussion
    Last Post: 01-17-2012, 06:28 AM
