Thread: Is a SSIC worth it?
Results 1 to 20 of 69
  1. #1 Re: Is a SSIC worth it?
    Kemmerer, Wyoming
    you don't need bigger injectors or an upgraded fuel pump for methanol. if a fuel pump is going to fail, it will fail in the summer or winter. you need to learn to get information from other sources than zzp. that methanol kit for sale on the classifieds is complete. all you need to do is install it, fill the reservoir with methanol and go. some people say to lean the air fuel ratio, other people say not to, because when you inject methanol, your air fuel ratio will go rich.
  2. #2 Re: Is a SSIC worth it?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by SgtMarshal View Post
    Okay seems pretty easy so the meth tank is separate you mount it in the trunk how much meth does it hold? How much do you actually use? I'm assuming there are different jets or nozzles? What kinda gains? Pulley drop?
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  1. ssic
    By oneredi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2012, 03:40 PM
  2. Ssic
    By boothe in forum Wanted To Buy - Parts
    Last Post: 02-29-2012, 10:55 PM
  3. Is it worth it to put more money into the car than what its worth?
    By xander37 in forum General Tech Discussion
    Last Post: 01-17-2012, 06:28 AM
