you don't need bigger injectors or an upgraded fuel pump for methanol. if a fuel pump is going to fail, it will fail in the summer or winter. you need to learn to get information from other sources than zzp. that methanol kit for sale on the classifieds is complete. all you need to do is install it, fill the reservoir with methanol and go. some people say to lean the air fuel ratio, other people say not to, because when you inject methanol, your air fuel ratio will go rich.
Okay seems pretty easy so the meth tank is separate you mount it in the trunk how much meth does it hold? How much do you actually use? I'm assuming there are different jets or nozzles? What kinda gains? Pulley drop?
Sent from my SM-G920V using Tapatalk
00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
