Thread: Some more top swap questions! Yay!
Page 63 of 71 FirstFirst ... 13536162636465 ... LastLast
Results 1,241 to 1,260 of 1411
  1. #1241 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Well i didnt do anything that i know of but recently my fuel trims have been looking pretty decent usually always with in +/- 5 and its usually more a little rich now then lean which is the complete opposite of how its been
    Sent from my LG-D851 using Tapatalk
  2. #1242 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    That's good, but adding the race gas, I wouldn't do anything with tune until you cycle through some tanks on 91, then scan and adjust timing or fueling appropriately.....or just got on e85 ASAP
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  3. #1243 Re: Some more top swap questions! Yay!
    you highlight the bottom 4 rows from where ever the kr starts on your scan, i got it highlighted from 3200 to 6400 rpm. then right click and select up or down.
    your timing should look the same as mine here. its a tad lower then stock gtp files.
  4. #1244 Re: Some more top swap questions! Yay!
    Quote Originally Posted by suitercrew View Post
    just so we're clear, a neg # is rich, pos is lean.
  5. #1245 Re: Some more top swap questions! Yay!
    Oct 2015
    Yes sir gotch ya!! Well ill let you guys know how the tuning goes. Its supposed to be here tomorow
  6. #1246 Re: Some more top swap questions! Yay!
    we're gonna hear from you long before that lol how the F do i get this thing registered!!!!!!!!*)^$%&(^*^%*^$ lol
    it can be a real pita to figure out for some.
    if the unit you bought has a key span adapter you need a driver for it, and getting the right driver to work can be some work. drivers are on line easily found.
  7. #1247 Re: Some more top swap questions! Yay!
    Oct 2015
    My unit does have a key span lol
  8. #1248 Re: Some more top swap questions! Yay!
    your looking for the USA-19HS driver for your os. heres the list http://www.tripplite.com/support/downloads/type/9/tab/2
  9. #1249 Re: Some more top swap questions! Yay!
    Oct 2015
    Hopefullu they have the right one i have windows 8 and there arent very many drivers for that and idk which model keyspan it is
  10. #1250 Re: Some more top swap questions! Yay!
    i posted it, ^^^^ and win 8 is ok
  11. #1251 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok boom got it thanks scotty! One less thing to worry about
  12. #1252 Re: Some more top swap questions! Yay!
    Oct 2015
    Om having trouble installing the .net framework it keeps telling me i already have a version installed but it wont let me open the dhp scanner
  13. #1253 Re: Some more top swap questions! Yay!
    you cant do a thing till the cable is registered, as i told you like 8 posts a go.
  14. #1254 Re: Some more top swap questions! Yay!
    Oct 2015
    O i thought i could just get everything downloaded and setup but ok ill wait thanks.
  15. #1255 Re: Some more top swap questions! Yay!
    tools, then interface registration, thats all that works. once you get that done its unlocked.
  16. #1256 Re: Some more top swap questions! Yay!
    Oct 2015
    Got ya thanks scotty!
  17. #1257 Re: Some more top swap questions! Yay!
    Oct 2015
    I got my dhp today! Im still having issues with opening the scanner but i read my bin and then i compared it to a stock l67 bin and my bin is calling for a pretty fair amount of timing more than the stock l67 bin which i thought was odd
  18. #1258 Re: Some more top swap questions! Yay!
    Montgomery, IL
    A tune usually adds timing so not really odd...you want as much timing as possible. That's where the powers at.
  19. #1259 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    there are several versions of uv scanner, you have to download each one and try it to see if it works, and if it doesn't, uninstall it and try the next one. can you post a link to your bin? I have a dropbox and used that for a lot of tuning stuff, but it's full now, so I am using a google drive account to upload stuff. Timing advance creates more pressure inside the cylinder because there is more combustion, and with the supercharger also pushing air, the risk for more detonation is higher.
  20. #1260 Re: Some more top swap questions! Yay!
    you can use the dhp scanner for now, it works fine for what you need.
    uvscan also needs to register the cable so to say too. iirc theres a data base for it as well to be installed in a file folder and selected.
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
