Thread: Some more top swap questions! Yay!
Page 61 of 71 FirstFirst ... 11515960616263 ... LastLast
Results 1,201 to 1,220 of 1411
  1. #1201 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Where do i get the software and how do i register. I googled for software but it seems most of the forums that had it are shut down
    Sent from my LG-D851 using Tapatalk
  2. #1202 Re: Some more top swap questions! Yay!
    that drop box link a page back has everything you need to set up dhp.
  3. #1203 Re: Some more top swap questions! Yay!
    Oct 2015
    Hmm ok. Also ive been reading the user manual and it talks about how you can only use it on the model year and make you bought it for. Whats up with that?
  4. #1204 Re: Some more top swap questions! Yay!
    old manual from when you had to pay for credits like HPT now.
    those words mean nothing now. its free. ive used mine on a many different cars now.
  5. #1205 Re: Some more top swap questions! Yay!
    Oct 2015
    Great! Status update ive been driving with the a/c on because i dont get misfires when its on and my ltft is still out of wack while driving its always in the positive never once goes in the negative it usualy stays in 0 to +7 range
  6. #1206 Re: Some more top swap questions! Yay!
    Oct 2015
    O and vaccum gauge still bounces back and forth between 20 and 16 for no apparent reason
  7. #1207 Re: Some more top swap questions! Yay!
    you ever spray the engine down with carb cleaner? at idle the vacuum should be steady.
  8. #1208 Re: Some more top swap questions! Yay!
    Oct 2015
    I did spray everything with carb cleaner and i didnt get any changes in rpm the only thing i can think of is if theres a leak in the lim gasket. Would a leaky valve cause loss of vaccum?
  9. #1209 Re: Some more top swap questions! Yay!
    Oct 2015
    The vaccum isnt stable at idle usually bouncing 20-18 but when im actually driving and coasting to a light not on throttle it bounces between 20 and 16
  10. #1210 Re: Some more top swap questions! Yay!
    Oct 2015
    So ill be doing a dry compression test in the morning. If that cylinder is bad i heard you can do a wet compression test. What kind of oil and how much oil do you put through the plug holes for the wet test?
  11. #1211 Re: Some more top swap questions! Yay!
    For real, google that ****.
    You have the internet, use it man. Youtube a leak down/compression test.
  12. #1212 Re: Some more top swap questions! Yay!
    Oct 2015
    So i just drove all the way home from work with not a single misfire on any cylinders soo wth is going on grrr.
  13. #1213 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Smh you act like we are there in front of your car who knows what ya did.....
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  14. #1214 Re: Some more top swap questions! Yay!
    Oct 2015
    ... Yaa but in my dreams you are !
  15. #1215 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    The fu*kk?? This is why when you don't know what your doing chances are you shouldn't do it this thread is so shot lol
  16. #1216 Re: Some more top swap questions! Yay!
    Oct 2015
    So i went to my dads house today and got the compression tester. Then i went down to the exaust shop and they didnt find any leaks with the headers and then i found a place that sells 100 octane so i put a few gallons of that in to achieve closer to a 93 rating and now im only at 1 degree or less of kr at wot. Amazing that a little bit of high octane can do that much.
  17. #1217 Re: Some more top swap questions! Yay!
    that means its the tune that needs help. unless you want to run 100 octane lol
    how was the compression test? still misfiring?
  18. #1218 Re: Some more top swap questions! Yay!
    Oct 2015
    I have the tester but havent run the test yet. It hasnt misfired for two days. It was 9$ a gallon for 100 octane... Although they had 110 for 9$ as well but i think it was leaded
  19. #1219 Re: Some more top swap questions! Yay!
    Oct 2015
    Hey scotty what kind of operating system works with the dhp. I was looking for an xp but now a days its hard to find one that old. Does vista or 7 work?
  20. #1220 Re: Some more top swap questions! Yay!
    vista works fine too xp to win 10 all work.
    its just the older laptops with xp or vista are way cheaper of course.
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
