Thread: Some more top swap questions! Yay!
Page 37 of 71 FirstFirst ... 27353637383947 ... LastLast
Results 721 to 740 of 1411
  1. #721 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Follow the sticker all gm rocker bolts are tq then the 90° even the stock ones it says it right in the Haynes manual I don't know where 25ft lbs came from.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #722 Re: Some more top swap questions! Yay!
    25 ft lbs is the spec for a re usable rocker bolt. done it a few times now, they dont go no where.
  3. #723 Re: Some more top swap questions! Yay!
    SE Level Member duswickware's Avatar
    Jan 2014
    mansfield, ohio
    I've had no issues with mine, same ones torqued to 25 lbs
  4. #724 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ok so i was putting my rear header in and went to connect the o2 extension and they sent me the wrong one. So can i just get some wire, cut and solder the old harness?
    Sent from my LG-D851 using Tapatalk
  5. #725 Re: Some more top swap questions! Yay!
    you can cut the plug off the cars harness and make it longer from that side. you cant cut the o2 sensor wires. one is ss.
    make sure you beat the fire wall for the o2. or you'll be sorry later on.
  6. #726 Re: Some more top swap questions! Yay!
    Oct 2015
    Thanks for the info scotty! Does anyone know which wires you splice for new map plug
  7. #727 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Zzp sells a 2 bar map that plugs right in to your harness
  8. #728 Re: Some more top swap questions! Yay!
    Oct 2015
    Well i have the l67 plug not the 2 bar map lol
  9. #729 Re: Some more top swap questions! Yay!
    Oct 2015
    Hey how do i break the crank bolt. No i dont have a impact
  10. #730 Re: Some more top swap questions! Yay!
    you should have taken that off first, while it ran still. could have done the redneck method.
    now you'll need vice grips on the flex a breaker bar and a pipe.
  11. #731 Re: Some more top swap questions! Yay!
    Oct 2015
    Whats the flex?
  12. #732 Re: Some more top swap questions! Yay!
    the round thing with teeth on it for the starter. flex plate.
    take the plastic cover off the bottom, a few 10mm bolts, then take the starter off, then vice grip the fat part of the flex near the teeth really tight.
  13. #733 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Lmao good luck with that whatever you do don't ruin the flex plate best to try and get a impact
  14. #734 Re: Some more top swap questions! Yay!
    Oct 2015
    Im just gonna put it all back together and use the starter to break the crank bolt
  15. #735 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    I'd try and get a impact you do have to impact the new one on to
  16. #736 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I'm sure any auto parts store will rent you one.
  17. #737 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok ill check in on the rental!
  18. #738 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    I've never heard of a auto parts store renting one? You can buy a cheaper one if you have a air compressor do you have a harbor freight?
  19. #739 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya i have a harbour freight but my dad has an impact but he didnt think his would get it off because its one of the cheaper ones
  20. #740 Re: Some more top swap questions! Yay!
    Apr 2015
    Quote Originally Posted by Tonkin2000GT View Post
    They rent every other tool, why not an impact?
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
