Thread: Some more top swap questions! Yay!
Page 35 of 71 FirstFirst ... 25333435363745 ... LastLast
Results 681 to 700 of 1411
  1. #681 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Yea I'm just telling you **** sucks terrible design
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #682 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Well thanks for the heads up man.
    Sent from my LG-D851 using Tapatalk
  3. #683 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Yupp that's another reason why I had zzp weld my coolant holes shut because of what I went through and I didn't want to rely on dimes that could potentially ruin my whole motor again if you know what I mean
  4. #684 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya i just said screw it i figured the gaskets orings are better then dimes and ill probably want to take it apart and put an intercooler on way before the orings go bad
  5. #685 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Yea I agree with you but most people do it anyways because it's dumb to have hot coolant running into the supercharger it just heat soaks the heaton even more lol
  6. #686 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    When you intercool it the coolant holes have to be welded shut though. But remember when I told you it's alot more then you think to do a top swap? Lol I wasn't kidding after I got done with mine I thought to myself it would have been easier and cheaper to find a low mileage L67 and just change the motor.
  7. #687 Re: Some more top swap questions! Yay!
    Oct 2015
    The best i could do atleast locally was find an l67 for 1000$ that had 180k. Im probably 1000$ invested so far, i get to keep my 95xxx mile bottom end, replace all the gaskets and fluids, and add headers and a tune for that much. So although easier for sure not so much cheaper from my pov
  8. #688 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    You don't have to weld the coolant holes shut, jb weld and a dime work fine, or you can tap the holes and use threaded plugs
  9. #689 Re: Some more top swap questions! Yay!
    Oct 2015
    So im ready to put the new head on i think my dad told me not to bother cleaning the piston tops because its not really worth the risk of possibly getting crap down in the cylinder and damaging the piston rings
  10. #690 Re: Some more top swap questions! Yay!
    Oct 2015
  11. #691 Re: Some more top swap questions! Yay!
    you can bring each piston to the top, smear some grease around the outer edge. if you got air you can just as easy blow any carbon out of the groove too.
    tops of my l36 were nasty, like 3mm thick of carbon, i cleaned em up.
  12. #692 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok and this might sound extremely dumb but do the heads have their own side or are they exactly the same placement
  13. #693 Re: Some more top swap questions! Yay!
    they are the same. dont matter what side they go on.
  14. #694 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok great and the permatex copper you just spray on a thin layer on both sides correct?
  15. #695 Re: Some more top swap questions! Yay!
    i hung mine off the garage door track with a bungee cord, and sprayed it, 2 light coats iirc.
  16. #696 Re: Some more top swap questions! Yay!
    Oct 2015
    But it goes on wet right?
  17. #697 Re: Some more top swap questions! Yay!
    tacky still.
  18. #698 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok and my dad asked me if i figure out how to adjust the rocker arms. They dont need adjusting do they?
  19. #699 Re: Some more top swap questions! Yay!
    nope, just tq em down to 25 ft lbs.
    do clean the threaded holes out good. make sure they are oil free, brake cleaner and some Q tips works well. this way the bolts are tq'ed properly.
    you can put a dab of grease on the top of the push rods and a smear on the valve spring stem too. keeps you from having a bone dry start up. just a little bit of grease, you dont need a whole lot.
  20. #700 Re: Some more top swap questions! Yay!
    Oct 2015
    Well im gonna reuse my l36 pushrods and rockers since i wasnt able to get the 1.9s so there still pretty oily haha
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
